1993 water pump
Old Feb 10, 2015 | 11:00 PM
1969Mike's Avatar
1969Mike
Default 1993 water pump
Hi guys,
I found a beautiful '93 convertible with only 34k miles. It looks brand new. ALL the fluids have been recently changed. My question is, what is your opinion about doing some preventative maintenance? Mainly thinking about the water pump. If it goes, there goes the Opti-Spark. I know it sounds like I've already talked myself into it, but would just like some expert opinions. I've owned a C4 before, but it was a '90 ZR1, so this ia a different ballgame.
Old Feb 11, 2015 | 01:05 AM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Depends. Is there any sign of leaking at the weep hole at the bottom of the pump? If all looks and sounds good, then IMHO I'd leave it alone.
Old Feb 11, 2015 | 01:37 AM
1969Mike's Avatar
1969Mike
Thanks, it's just that our club is planning a day trip in April & I was thinking better safe than sorry. I'm just remembering an Olds I inherited from my father 25 years ago. He hardly drove that car and everything seemed to check out OK before I drove it home (1100 miles). Fortunately, I made it all the way home. The next day there was a puddle of coolant under the car. You know what happened.
Old Feb 11, 2015 | 06:15 AM
Bandit's C4's Avatar
Bandit's C4
Central PA Events Coordinator
St. Jude Donor '12-'13
Put it on a lift and have a thorough inspection before throwing money at it....
Old Feb 11, 2015 | 09:41 AM
jph46's Avatar
jph46
Just put a new pump in my 93, 65k. Bearing in pump behind coupler was bad. Also replaced the seal on the timing cover. Purchased a ACDelco Pro water pump, didn't fit. Went to my local NAPA store $116 with a lifetime warranty fit great. Hard part was getting the old gasket material off, otherwise not that difficult.
Old Feb 11, 2015 | 10:14 AM
John A. Marker's Avatar
John A. Marker
If you decide to put on a new pump. Do yourself a favor and alter the pump at the weep hole. You can find a brass fitting (used for small diameter hose) that you can epoxy into the hole. Then run a plastic tube from this fitting down past the OPTI and use zip ties to keep in place.
Old Feb 13, 2015 | 10:45 PM
1969Mike's Avatar
1969Mike
Do you know if it had ever been replaced before?
Old Feb 13, 2015 | 10:54 PM
1969Mike's Avatar
1969Mike
Sounds like a wise thing to do!
Old Feb 13, 2015 | 11:56 PM
TractionControlOff's Avatar
TractionControlOff
I just had my water pump/opti replaced last summer ('94/45K miles). The car was starting to act up a bit at low speeds, so it was definitely time. It's a hassle but the car felt like new afterwards.
Old Feb 14, 2015 | 12:43 AM
dizwiz24's Avatar
dizwiz24
if its not broke dont break it by replacing it...
Why?
The new ones are made in china (even though you still pay top dollar and it says ac delco)
Get your old one rebuilt in the usa (someone on here has contact info for someone that does 'em)
I do agree with the weep hole vent...vent the weep hole away from the opti for if it does go bad
Old Feb 14, 2015 | 09:14 AM
jph46's Avatar
jph46
No, it was the stock one. I also replaced the distributor cap and rotor with a MDS kit, the kit has a venting system, which the stock one does not have. Replacing all the cooling hoses today and get her back on the road.
To 1993 water pump
