Sears DieHard
Old Mar 2, 2015 | 12:29 PM
AstroMan1's Avatar
AstroMan1
Default Sears DieHard
Should I ask for a new one?, I bought one Dec. 5th and it would not start the car today. I haven't driven it for almost a month because of the weather here in WV, down to -8 one night and really cold most of the time. I don't even have a garage right now, I'm keeping the car at a friends outside, ouch, so no battery tender is possible. It's a Sears DieHard Gold
Old Mar 2, 2015 | 12:45 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Take it in to Sears. They will test it for free and if it needs to be replaced they will replace it under the warranty. IF it just needs to be recharged they will probably recharge it for free as well. I've always used DieHard Gold in all my cars including my two vettes.
Old Mar 2, 2015 | 12:51 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Good advice...
Old Mar 2, 2015 | 01:06 PM
c4cruiser's Avatar
c4cruiser
Cold weather can be hard on a battery especially if it's installed in a car and if that car may have some components that have some amount of current drain.
I would think that Sears would re-charge the battery and perform a load test on it. A fully charged 12 volt car battery should show about 12.7v when fully charged.
Once you get it re-charged, check for current drains. It's possible that small thing may have caused the discharge. Interior lamps such as a glove box light, sunvisor light, console light may be on and that will easily drain a battery. Is there any reason why you can't use a long extension cord at your friend's house? Even a 100' cord and a small battery tender like a Deltran Battery Tender Junior that's kept under the hood will work fine.
If you don't intend to drive the car for awhile, it may be a good idea to simply not re-install the battery. With the battery fully charged, it can sit inside and it will be ready to go as soon an you install it. But definitely check for any current drains.
Old Mar 3, 2015 | 11:32 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
Sears will do you right. They'll either recharge it, or give you a new one for free.
If you don't put it back in right away, make sure you don't set it on the floor until you're ready. That will cause a battery to go dead. (Set it on a chair or table)
You could also put it back in the car, but leave the negative cable disconnected until you get a chance to check things out.
Old Mar 3, 2015 | 11:55 PM
jsdomino's Avatar
jsdomino
Buy one of these:
http://www.harborfreight.com/15-watt...ger-68692.html
Old Mar 4, 2015 | 12:48 AM
desertmike1's Avatar
desertmike1
Originally Posted by jsdomino
It won't do him any good! Car is outside without the availability of A/C power..
OP your best course of action would be to remove the battery for a recharge,,, I would avoid jump starting at all cost!
Old Mar 4, 2015 | 03:37 AM
enventr's Avatar
enventr
I would remove the battery in the winter and bring it indoors if you use it once a month especially if it's that cold. If possible try renting a garage for the winter
Old Mar 4, 2015 | 05:57 AM
HlhnEast's Avatar
HlhnEast
Johnny, I am going to clarify a bit here. Semantics, I know. Do not set the battery on a concrete floor or directly on dirt. Always use some insulating property like a 2X12 or similar. Better not to have it anywhere near the ground. As Johnny mentioned it will kill it deadern a doornail!
Old Mar 4, 2015 | 06:06 AM
desertmike1
Actually this no longer applies to modern batteries, the Plastic Battery housings no longer seep like they used to 50 years ago..
http://www.snopes.com/autos/techno/battery.asp
Old Mar 4, 2015 | 08:47 AM
ghoastrider1's Avatar
ghoastrider1
Keep in mind that you don't want a "high charge" or high current draw while idleing for long periods. That puts your charging system working at its hardest and it may not be able to handle it for long periods. You ever see the young guys with the high powered amps for the bass woofers sitting in a parking lot wanting a jump? Besides taking the battery out, I simply disconnect the ground cable to the battery if My car is going to sit for long periods.. a 5/16 inch wrench is cheap. good luck, like others say, sears will take care of you
Old Mar 4, 2015 | 02:14 PM
AstroMan1's Avatar
AstroMan1
Thanks guys, sorry it took so long to get back to you, I appreciate your help. I wonder what do car dealers do when cars sit for a long time, I can't believe I had this problem.
Old Mar 4, 2015 | 02:51 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Need to work on your winterize methods. Charge, and disconnect the battery. Before you remove the panel, and battery, charge the battery, and see if it holds the charge.
C4cruiser is right:
Old Mar 4, 2015 | 04:48 PM
cigr's Avatar
cigr
Did you look at his link? It's a solar trickle charger. No access to A/C power is needed.
Old Mar 4, 2015 | 09:41 PM
desertmike1
Very nice! OP needs to remove the Battery, and store it in a warmer invironment during the winter months in order to keep it from freezing, due to a low charge state.. other wise this option doesn't look bad at all for the warmer months.
The other Option would be a battery tender connected to a power source, as long as the battery remains at or near a full charge it won't freeze.
http://blogs.cars.com/kickingtires/2...ry-freeze.html
Old Mar 6, 2015 | 01:06 PM
jake corvette's Avatar
jake corvette
The cooler the ambient temp, the slower the self discharge rate - see here -
Make sure the battery is disconnected or parasitic drains will discharge the battery -
http://www.pbase.com/mainecruising/self_discharge
http://powerelectronics.com/site-fil...s-Figure04.jpg
Old Mar 6, 2015 | 01:46 PM
markKlein's Avatar
markKlein
They have guys that go around the lot and put a charger on the cars on a regular schedule.
Old Mar 6, 2015 | 02:03 PM
abdo's Avatar
abdo
2016 C1 of Year Finalist
FWIW I have Sears Die Hard batteries in my two C1s and they have given me great service. During winter storage I use a battery disconnect and charge them with a maintenance charger once a month. They usually reach full charge within minutes.
I think with any battery, the key is to keep them charged.
To Sears DieHard
