new engine
Old Mar 6, 2015 | 05:04 PM
bunman90's Avatar
bunman90
Navigator
Default new engine
I have 90 convertable with a ton mile and problems.
Do you re-build the engine or do a crate engine.
There a ton of c4s around and I'm over showing cars
Old Mar 6, 2015 | 06:02 PM
c4cruiser's Avatar
c4cruiser
What is the car used for? DD? Sunday cruising? Long trips? How much longer do you want to keep the car?
I think the replacement engine choice depends on a number of factors; the cost of another engine can vary based on a local rebuild of your engine or simply buying a complete long-block replacement. Are you going to do the engine R&R yourself? Have a shop do it? Do you have any power goals? Stock engine or add go-fast stuff?
One thing to consider is that most good crate motors will have some warranty period. It can be from 1 year/10K miles to as much as 3 yrs and 100K miles. Taking your engine to a machine shop for a rebuild may only get you 90 days/1000 miles for a warranty. And that may only be for the machine work, parts they provide, and assembly.
Crate motors come fully assembled and ready to install. Figure a week or less from the time you order to having the delivery truck pull up to your garage. Depending on how busy a local machine shop is, it could take up to a month to get your engine back.
Old Mar 6, 2015 | 06:18 PM
bunman90's Avatar
bunman90
Navigator
Default new engine
DD kinda and will keep it for ever. It looks great. ...will not work on myself
Old Mar 6, 2015 | 06:54 PM
jakenks's Avatar
jakenks
Might be reasonable to get a crate replacement and have it drop shipped to whoever is going to do the install. FWIW, you may save a **** ton of money if you work with the shop about doing some or all of the old engine removal. Like was said, most crate engines have a warranty. Jegs has some good deals right now, with free freight.
Old Mar 6, 2015 | 11:19 PM
agoguen's Avatar
agoguen
Navigator
Default engine
I just bought a new long block, (stock) having a shop do the labor.
old one had 120K and I bow a head casket and eat a piston or something, cause it made a hell of a noise after over heating due to
blown head gasket and the drain plug blown out of the rad...I use it as a DD about two ride a day around my area here in Florida. I am retired and love to drive it, its just a toy for me....my 3rd vet.(67-427 was 1st, then a 68 327-350 horse as 2nd, now this one.) The engine cost me 2600 and labor 1600, plus new water pump, opti-spark, rad, all new hoses and belt, thermostat. I am guessing that it will be good for another 120K easily. Dropped it off last Wed and should have it back Mon or Tue.. 3yr unlimited miles....every thing came to 5 grand. Thats about all the car cost me.... LOL Men and their toys huh????
Old Mar 7, 2015 | 11:48 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You can have a Jasper remanufactured engine installed very reasonably by most shops.
Ever think about a used one? Do a search for Corvette recycling to find one. I like www.vette2vette.com
Old Mar 7, 2015 | 01:54 PM
c4cruiser's Avatar
c4cruiser
that Jasper is a very good choice for a reman engine. Their replacement engines have a 3 year/100K warranty. And if you don't want a stock replacement, Jasper has a very good line of performance engines that will save you from having to figure out what upgrades will work. It's too easy to get talked into parts that won't play well together...
To new engine
