'93 Runs rough when warm
Do any of you guys have any idea what it might be? The "Corvette Expert" at the dealership didn't know.
It only runs bad when it's warmed up. When it gets to a certain temp, it starts running really rough. Could a bad optispark be temperature sensitive? When it's cool it runs fine.
Thanks.
Had the same issue - would stumble and fall on its face stalling out at warmed up temps.
https://www.corvetteforum.com/forums...ignal-low.html
To answer your last question, yes, a failing optispark can be very temperature sensitive. If he notices his tach bounces and then drops to 0 then it is more than likely the opti. Had it happen a few times. Sad thing is no one really makes quality replacement units anymore.
Does the car shut off on him at times, and does it only crank if and when it shuts off?
While in open-loop mode, the fuel is metered according to a separate table, independent of O2 readings. But, when switching to closed-loop, then the O2s are considered in the AF mix. Until that happens, everything runs just fine: no codes either. But, as was the case with my 95 LT1, soon as it went closed loop after warming up to temp, it would run like crap.
I too took it to a dealer to fix. But, when I picked up the car, the note on the work order said, "No problem found". Yeah, well, before I got it home (45 minute drive) it was running like crap (and a friend that was following me home called me on my cell phone to tell me the right side exhaust was pouring black smoke!).
In my case, the problem was intermittent to boot: sometimes would act up and sometimes would run great all day. I figured that was the case w/ the dealer too, so I bought my first scanner that had the ability to record "events" and save them to be downloaded (on a PC) later.
Long story short, it was a funky O2 sensor that wuz internally shorting out, indicating an extreme LEAN condition (whereupon the computer was compensating by commanding the injectors on that side to dump buckets of fuel on that side of the motor to correct the lean indication!).
So...your symptoms are like "dejavu all over again" (to quote Yogi Berra). A scanner might unlock some surprises too. (It gave me no small pleasure to diagnose the problem and fix it. Then I presented the dealership's manager with my printout showing the problem printout, and I got my money for the "no problem found" refunded.
Hey Ozz! Your the guy with the youtube videos! This is franco!
