A/C drain line
Old Mar 19, 2015 | 05:34 PM
Fast Jimmy's Avatar
Fast Jimmy
Default A/C drain line
My 95" is getting wet carpet on the passenger side. I believe it's condensation from the a/c that's not being drained away as there is no anti-freeze smell to it so it's probably not the heater core. But, I can't find where it's supposed to drain from. There apparently is no drain tube. Anybody know what I should be looking for?
Thanks, Jim
Old Mar 19, 2015 | 05:59 PM
antfarmer2's Avatar
antfarmer2
On my 94 there I heard there are three drain tubes one behind the battery one in the center and one on the pass side might have to take off the bottom side cover to find it
Old Mar 19, 2015 | 07:15 PM
mike c4's Avatar
mike c4
Thanks, Jim
there is no drain hose only a hole in the box take out the blower fan and you will see it
Old Mar 19, 2015 | 07:53 PM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Interesting, GM must have discontinued putting them in the later C4's because my '87 sure has one---specifically for the evap core box drain, (in addition to the 3 cowl drain tubes). It's a fairly large tube, pinched at the end, under the blower motor. It's easily seen and accessed by removing the rh lower fender---and yes, they do get plugged.
Old Mar 19, 2015 | 08:54 PM
mike c4's Avatar
mike c4
my 1996 had no drain tube only a small hole in the box you can see the hole by the above the fuel filter but to me it was easier too pull the blower motor
Old Mar 19, 2015 | 10:13 PM
Fast Jimmy's Avatar
Fast Jimmy
Default A/C drain
Thanks guys, I now know where to look and what other parts to remove.
JIm
Old Mar 20, 2015 | 12:27 AM
Cliff Harris's Avatar
Cliff Harris
I thought mine would have a drain tube, but it doesn't:
If you have water inside the cabin then it came from the heater core.
Old Mar 20, 2015 | 07:32 AM
Yorcci's Avatar
Yorcci
If it's a small leak, it doesn't necessarily have the 'anti-freeze smell'. Been there, done that. http://finnshark.com/forum/showpost....postcount=2202 Don't mind the language. It's Finnish. But look at the later pics, you'll see how little the leak was with mine. That was enough to put a hazy layer on the windows and wet the passenger's floor. That hazy layer was easy to identify as coolant, since it felt very oil-like, but it could be wiped off with a damp cloth => water soluble ingredient = has to be coolant.
If it has just started and you are sure there's no leaking from the weatherstrips, then it's the heater core.
Old Mar 20, 2015 | 11:20 PM
Fast Jimmy's Avatar
Fast Jimmy
Default A/c
Well, it may be more than a leak from a plugged drain,,,But! I got under and looked just above the fuel filter and there is a hole that was plugged with leaves. I think I will see if that takes care of the issue before I tear the heater core out.
Many thanks for the advice. Jim
To A/C drain line
