Is this safe?
Old Aug 11, 2002 | 10:04 PM
Bat Man's Avatar
Bat Man
Default Is this safe?
I took my spare tire carrier and tire off. Is it safe to go to a car wash place, select the engine degreaser and spray back there in my rear suspension?
Old Aug 12, 2002 | 02:54 AM
morphious's Avatar
morphious
Default Re: Is this safe? (Marty McFly)
I don't see why not, mine is off but haved not cleaned down there yet. :cheers:
Old Aug 12, 2002 | 03:28 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Is this safe? (morphious)
:yesnod: :yesnod: :yesnod:
GO for it!
Old Aug 12, 2002 | 11:34 PM
R23HTC's Avatar
R23HTC
Default Re: Is this safe? (Sharky Guam)
As long as it doesn't make it up front to the opti, you should be okay.
Old Aug 13, 2002 | 08:01 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Depends on the degreaser. I heard that some degreasers could damage your springs. Could be wrong though.
Old Aug 13, 2002 | 08:37 AM
ToniH's Avatar
ToniH
Default Re: Is this safe? (Red 90 L98 Coupe)
I agree with this. Some bottles even say "don't spray on rubber or plastic parts". If I were you I would protect the rear spring very well before starting just to be on the safe side. It could be dangerous and expensive to damage it in any way.
BTW...this also goes with exhaust installation...it is very easy to overheat the spring if it is welded together. Most muffler shops don't realise the spring is composite and they are not carefull enough under there.
tonih
To Is this safe?
