Keyless entry?
Also, about remotes being able to block the fob signal and prevent the car from locking. I'm not sure I understand; since the fob doesn't send a "lock" signal, what is masked? The car locks when it detects the lack of fob transmission, so how would a signal being masked or blocked keep it from locking?
Infra red would be, well, it just wouldn't work. Consider if you will the garage door opener. That little electric eye at the bottom of the door that stops it from closing if you walk in front of it, that is infra red. If must have a direct line of sight in order to work. RF does not. Needs a transmitter and a receiver. Now, that other thing. The door bell. I saw this demonstrated. I believe what is happening is the door bell remote emits a RF frequency the either amplifies or cancels the sine wave (the RF signal) being emitted by the key fob. Kind of like a jamming device James Bond would use. Or Captain Kirk. By changing the sine wave the key fob emits you are in effect changing it's frequency. The receiver on the car that would pick it up and open the doors does not recognize it. So, if you park your car, hit the button while someone else is pressing their door bell remote (hoping to steal your car), the car won't lock. Now, I imagine this will not work with every door bell or with every car. Or even any car. I can neither confirm or deny. I just thought it was interesting. And I've probably confused EVERYONE! Sorry folks. This really is a silly thread. But, what else are we gonna do. Replace our ball joints?
Class adjourned.
Class adjourned.
1. The remotes of yesterday worked on ultrasonic tones (above human hearing levels) and your dog's tags may very well have been able to change the channel but it was due to a harmonic of the frequency of the remote and it's receiver.
2. All things in the spectrum are waves. Be it Radio, visual or audible. All of these waves need a "transmitter" and "receiver". The difference is Radio Frequencies (RF) are caused by electromagnetic excitation (electrons), Audio Frequencies are caused by percussion and vibration through a substance such as air or water (doesn't travel in a vacuum), and light waves are photons. While both photons and electrons travel at the speed of light (and vacuum i.e. space), audio waves travel at the speed of sound. You can not hear RF or light. You may hear a buzz created by vibrations by an electromagnetic force but this is not hearing RF.
- RF needs a transmitter like a radio station and a receiver like your radio
- Audio Waves need a transmitter like your mouth and a receiver like your ears
- Light waves need a transmitter like the sun and a receiver like your eyes. Just like that IR LED in your garage door opener sensor. It has a transmitter (the LED) and a receiver (the light sensitive diode).
3. In order for the Garage door opener or doorbell transmitter to stop your key fob from locking your door there has to be a few things happening here. One, both the key fob and the doorbell transmitter have to be on the same frequency or some harmonic of that frequency. Two, the jamming transmitter (doorbell transmitter) has to be very powerful (wattage) or has to be very close to the receiver (car). The other scenario is the Key fob has to be very far away and of lower power than the jammer. Three, be very lucky!?
http://www.google.com/patents/US4942393
http://www.google.com/patents/US5319364
As for some remote being able to block a lock signal to your car, I totally see how this could happen; but I would think irrelevant to a C4 discussion, since there is no "lock" signal to block.
There would still be the issue of starting the car as they would not have the key for the ignition. VATS is a whole other issue in itself.
PKE for me is PROXIMITY so the answer is I guess NO - NEVER
JR
The key was cut by a professional locksmith and appears dead on.
VATS key blade is maybe 37.5mm +/- from head and a "letter blank" is something closer to 30mm +/-. The effective length of the 6 cuts is the same but overall length wouldn't allow function.
Generally a "work-key" is the only key done less the resistance feature and is brass. If VATS is disabled a key with any resistance feature would work if the mechanical cuts were correct. The "work-key" is much softer material and I'd think not a good choice for everyday use.
It operates on a radio frequency. It does have an unlock button (Pass side only) but only works if you have turned off the auto unlock/lock on the car thru the fob. I think my neighbor thinks I had "lost it" but rocking the car does unlock the doors if it is in the auto mode if the keys are visible to the antenna. You have to let the fob "go to sleep" for a minute or so first! I think GM should have spent more time on the Opti instead.
The unlock button for the pass door always works, same as the hatch button (if you have one).
