Brake front caliper bracket
Old Apr 4, 2015 | 11:22 AM
BUNGERV87's Avatar
BUNGERV87
Default Brake front caliper bracket
What size is the bolt the holds the bracket on.
Thanks Bill
Old Apr 5, 2015 | 01:35 AM
Cliff Harris's Avatar
Cliff Harris
That's a little vague...
Depends on the year and the brake option.
Old Apr 5, 2015 | 09:00 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Also....are you looking for head size (socket size) or thread size??
A typical bolt might be:
8x1.25x35 with a 13mm head.
The 8 would be thread diameter in millimeters.
The 1.25 would be thread pitch (distance between threads)
The 35 would be shank length.
Many folks would call that a "13mm" bolt, because it takes a 13mm wrench/socket. That would be incorrect; it is an 8mm bolt.
Old Apr 5, 2015 | 09:11 AM
WVZR-1's Avatar
WVZR-1
Thanks Bill
Front information:
Bracket mounting bolts for '84 are M12 X 1.75 x 40, all others ('85 to end of production C4) are M14 X 2.0 X 47
M12 hex is generally M18 hex and M14 is generally accepted to be M21 - there are "exceptions" - reduced head flanged nuts and bolts are one and "heavy" hardware for construction another.
Rear information:
'84 rears are M10 X 1.5 X 32, all others M12 X 1.75 X 30 (likely).
M15 hex for the M10 hardware generally - there are exceptions.
To Brake front caliper bracket
