View Poll Results: Replace working Optispark when replacing Water Pump?
Yes; Replace the Optispark "while your in there"..
33.33%
No; Leave the working Optispark alone.
66.67%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Poll.. Replace working Optispark when doing Water Pump?
Old Apr 26, 2015 | 03:22 PM
AgentEran's Avatar
AgentEran
Default Poll.. Replace working Optispark when doing Water Pump?
When doing the water pump it is said that you should do the Opti "while your in there". This would basically mean replacing a functional and working Optispark..
Is it worth it?
Yes or No..
Old Apr 26, 2015 | 06:32 PM
MRPVette's Avatar
MRPVette
I personally wouldn't A good optispark is pricey just becarfule not to get it wet when removing the water pump.I forget which bolt it is but even after you think you have everything drained there is one bolt in the water pump were fluid pours out when you remove it.
Old Apr 26, 2015 | 06:57 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I would if yours is a 92-94 non-vented opti.
Old Apr 26, 2015 | 07:07 PM
Jon Hekking's Avatar
Jon Hekking
Old Apr 26, 2015 | 07:09 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
For the most part. Additionally, based on the plethora of "opti" posts on here, a replacement is not guaranteed to outperform an older, but working unit.
HOWEVER, I would for sure, remove the opti, clean the inside out good, and check the bearing and replace (the bearing) if necessary.
Old Apr 26, 2015 | 07:11 PM
Jon Hekking
If your car was over say 75,000 miles on the original non-vented opti, would you consider it?
Old Apr 26, 2015 | 09:01 PM
AgentEran's Avatar
AgentEran
It is indeed a non vented original Opti with 130k miles. Seems reasonable to be needing to be replaced with it being 22 years old.. But theres nothing wrong with it at the same time. I think I will just remove and clean it out and replace the bearing as suggested.
Old Apr 26, 2015 | 10:07 PM
jph46's Avatar
jph46
Just did my 93 a few months ago, don't forget to replace the oil seals on the WP and opti. I only replaced my rotor and cap, (65k),used the vented kit from MDS, opti was clean inside. Runs great.
Old Apr 26, 2015 | 11:38 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No. My car's original lasted until 155k. BUT, I'm good at, and enjoy wrenching, so for me, pulling the pump to get the the opti again, wouldn't be a big deal at all. 2 hours work at most. As unreliable as new opti's seem to be, if I had a good working one in my car, I'd inspect, clean, and keep running it. For people where the work far out weighs the cost of an opti, it would likely be worth replacing "while in there". And for anyone paying for labor on a water pump, it would definitely be worth it.
Old Apr 26, 2015 | 11:46 PM
Jon Hekking
Makes sense.................... As for me, I would avoid a repeat and do the both. Maybe I'll take it to my wife's office in Park City and let you do it.
Old Apr 27, 2015 | 12:07 AM
Polo Vert's Avatar
Polo Vert
Its common knowledge here that the aftermarket optis are not as good as originals, so why pull a unit thats better than what you can replace it with? If you must mess with it I'd do what jph46 did and just put the MSD vented cap and rotor on it. Most likely that will last longer than any aftermarket unit you put in there. My 94 has the original opti and 54k miles but I'm not gonna touch it until it gives me a reason to.
Old Apr 27, 2015 | 10:41 AM
RUU's Avatar
RUU
Other way around. Replace working water pump when doing Optispark.
Old Apr 27, 2015 | 10:51 AM
jph46's Avatar
jph46
If it's original (20 plus yrs), yes. Most difficult part of installing a water pump on the LT1 is getting the old gasket material off the motor, otherwise one of the easiest to replace.
Old Apr 27, 2015 | 12:05 PM
antfarmer2's Avatar
antfarmer2
Pull both knock sensors for a good flushing the only way to get it all
Old Apr 27, 2015 | 06:05 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I'd be happy to! I doubt you'd find a better value for that work anywhere. PM me if interested, I can give you rate, etc.
Old Apr 27, 2015 | 10:47 PM
Jon Hekking
Do you wrench? If so we may have met as there's very few mechanics in Utah I don't know through my time at CARQUEST, Mac Tools and Factory Motor Parts.
Old Apr 27, 2015 | 10:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I don't know if we've met or not, but I ran the Veh Maint shop at Canyons resort for 15 years....now I run a small shop out of my garage. Only place our paths may have crossed would be Park City Car Quest (when it was going), and MAC tools, but we never had much MAC service at Canyons.
Old Apr 27, 2015 | 11:05 PM
Jon Hekking
Interesting, we may have crossed paths. Greg Park should be in the canyons every Tuesday in his Mac truck, he's a great guy.
Old Apr 28, 2015 | 02:32 AM
JD Shredds's Avatar
JD Shredds
I'm generally of the don't fix what ain't broke mentality, and for me that applies to this as well, so long as you keep the Opti out of harms way.
Yeah. I'm newer to wrenching (started more seriously about a year ago) and I just did my WP/t-stat w/o Opti and it went well. Took way longer than it needed to, but now that I've done it I could see pulling it off in a few hours myself, and like I said I'm just a shadetree mechanic at best. Having to "do it over" doesn't intimidate me in the least if the opti were to go at some point.
And like you said, if you're paying for labor... yeah. Definitely want to consider opti as well in that case. But that still pushes the parts cost up significantly.
To Poll.. Replace working Optispark when doing Water Pump?
