Digital voltmeter
Old Jun 8, 2015 | 09:44 AM
JD1964's Avatar
JD1964
Default Digital voltmeter
I need to get a digital voltmeter for basic diagnostics on my vehicles. I don't want to pay extra for fancy stuff I don't need. Just enough for reliable occasional use.
What brand/model do you recommend?
Old Jun 8, 2015 | 10:33 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If you only need basic functions, you can get ones at Radio Shack (and virtually anywhere) for <$5.00 that will do everything you said you need.
Old Jun 8, 2015 | 10:35 AM
antfarmer2's Avatar
antfarmer2
Check the adds for harbor frieght they give them away all the time
Old Jun 8, 2015 | 10:59 AM
c4cruiser's Avatar
c4cruiser
Isn't Radio Shack gone now?
Check Sears for DVM's. They have some very good units for not a whole lot of money.
Old Jun 8, 2015 | 11:02 AM
WVZR-1's Avatar
WVZR-1
Nearly all are gone I believe. Our "local" told me on a Monday they were going to survive/remain open and end of that week they had the "going out of business" sales going on. I asked and they had no answer.
Old Jun 8, 2015 | 11:26 AM
don hall's Avatar
don hall
SEARS:
Craftsman Multimeter, Digital, with 8 Functions and 20 Ranges $19.99
on sale $9.99
Old Jun 8, 2015 | 11:30 AM
Klondike's Avatar
Klondike
I got a really nice one that checks nearly EVERYTHING.Volts AC & DC, OHMS. Can even measure capacitors and check transistors. Has a really handy continuity checker with audio "BEEP" for checking wires.
Craftsman at Sears for right at $20.00 ! One of my best deals on a really handy tool. Use it all the time.
Old Jun 8, 2015 | 11:33 AM
crowz's Avatar
crowz
Fluke is what I use but they aren't cheap.
My non fluke meters have always been the ones radio shack had but as mentioned shacks kind of gone now.
Be warned cheap meters aren't that accurate and they don't age well. The older they get the worse they read.
Not saying don't get one but I wouldn't go under say $30 at least the cheap $10 Chinese ones have tons of features but as mentioned don't age well and aren't that accurate to start with.
Old Jun 8, 2015 | 11:59 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I use a Fluke too...but he said "cheap" and "basic diagnostics". ...so
That's what I thought, but recently, I've seen several locations open, and their SITE says otherwise.
Old Jun 8, 2015 | 12:03 PM
don hall's Avatar
don hall
Show me a better meter based on price, quality, longevity, and I will agree:
Craftsman Multimeter, Digital, with 8 Functions and 20 Ranges ......on sale $9.99
Old Jun 8, 2015 | 01:19 PM
crowz's Avatar
crowz
I wasn't picking on a particular meter. I was point out the Chinese $10 and cheaper ones are junk and get worse with age.
My experience with craftsman electrical test equipment has been a hit or miss deal. Havent tried that particular meter so no opinion on it.
But I have bought other low priced craftsman test equipment and its been great for the price or utter junk. Like I said flip a coin. With sear's new way of selling things you really don't know what your buying from them 1/2 the time and would go by what a particular person recommends that they have bought and worked and not roll the dice on stuff not tried by someone already. Just my opinion.
If you bought the one your linking and it worked great the op should go for it.
Old Jun 8, 2015 | 01:46 PM
Paul Workman's Avatar
Paul Workman
Virtually any AutoZone, or like auto parts stores will have not only a DVM, but also some other automotive-specific electrical testing tools, e.g., spark testers, etc.
Just a suggestion...
For just a few $$ more, you may be able to get a TRUE RMS reading DVM. They have the advantage of accurately reading voltage levels regardless of wave (shape) forms (not just sine wave.) So, if accuracy counts, look for the one that says "TRUE RMS".
ALSO! There are times when you will want to measure current. I suggest you pick a meter that will read a minimum of 10 Amperes (a common amount for many meters). OR you can get some "clamp on" DC amp probes that attach to a DVM to measure AC or DC current; a VERY handy tool to have!
Old Jun 8, 2015 | 03:06 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I buy the chinese meters for the leads for my craftsman.
Old Jun 8, 2015 | 03:24 PM
don hall's Avatar
don hall
Will recommend your post to be a 'sticky'.
Old Jun 9, 2015 | 12:56 AM
Cliff Harris's Avatar
Cliff Harris
Even the junko meters are OK for the type of testing that we do.
Mostly you want to know if a voltage is there or not. Continuity is similar: are the two points connected or not? The only time we really need a sort of accurate resistance measurement is when measuring injectors. In that case look for one or more that are dramatically lower in resistance than the others.
Old Jun 9, 2015 | 05:25 AM
Grimlock13's Avatar
Grimlock13
Just what I was going to say.
Old Jun 9, 2015 | 06:02 AM
Joe C's Avatar
Joe C
- Fluke is good, and I still have my antique, Beckman 3010 (frickin' thing must be 35 years old), but for what most of us do - continuity, some resistance, and <20 VDC, cheap-o meters work just fine. w/ antfamer, free-bee's from HF fits the bill. I must have a half dozen, most, un-opened in my workbench drawer. figure I have a life-time supply - BTW, between 25 ft tape measures, little LED flashlights, multimeters, magnetic parts holders, screwdrivers, scissors, and an assortment of other crap, I've got this free-bee stuff coming out my ears! that's what happens when you have a compulsive disorder and live too close to harbor freight!!!
To Digital voltmeter
Old Jun 9, 2015 | 06:55 AM
WW7's Avatar
WW7
SEARS:
on sale $9.99
The problem I have found with these meters is they aren't accurate from one to another... I bought 3 of these cheaper units for my 2 "son in laws" and myself, and all 3 were off by at least 10% of each other..For me that makes them about as good as a test light......I wonder if they're even calibrated?......If you want accurate readings you have to spend some money.......WW
Old Jun 9, 2015 | 07:20 AM
kg4fku's Avatar
kg4fku
Interesting that there are recommendations for these really expensive meters and discussion of how these "cheap" meters are inaccurate. No multimeter is going to be as accurate as a dedicated meter. Not even those over priced Fluke meters. While they are compact, portable and convenient they are not as accurate.
The gentleman asked for a cheap and decent meter. I am sure he doesn't need or want to spend hundreds of dollars on a Fluke.
As for becoming inaccurate with age, all test equipment becomes inaccurate with age no matter what brand or how much it costs. Hence the reason for a calibration program. I have seen just as many Fluke meters tossed out as other brands due to failed calibration. Just because you pay more doesn't mean it is worth more.
I am not bashing Fluke. I use their equipment everyday and it works.
The OP deserves a realistic response to his specific question and not all of the fodder.
Old Jun 9, 2015 | 08:25 AM
JD1964's Avatar
JD1964
The Craftsman brand has always been good to me. I'll get one of those.
Thanks gents.
