DeWitts users, Step in please....
Old Jun 8, 2015 | 02:18 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Default DeWitts users, Step in please....
Installing my Direct replacement DeWitts radiator and there weren't any directions w/it. None online either, that I can see.
What are the two strips of adhesive-backed foam for, the screws, and the two plastic straps w/holes??
Old Jun 8, 2015 | 02:38 PM
crowz's Avatar
crowz
What year is the car your putting it in and is this your zr1 (Thought I read in the past that it was going in a zr1 you had) ?
Old Jun 8, 2015 | 02:44 PM
crowz's Avatar
crowz
Well without more info I don't know which instructions to post so I picked one
ok took out the instructions picture since the one I posted is the old one and isn't supposed to be used anymore according to dewitts.
Did find this though.
To clarify, the kit includes two foam strips and two spacer bars. The spacer bars are used to move the fans back 1/4" to allow room for the thicker core. We also include new bolts for that. Be-cool does the same thing, but they charge $75 for this spacer kit, and we include it for free.
Old Jun 8, 2015 | 02:45 PM
crowz's Avatar
crowz
Im guessing the foam goes on the top and bottom of the radiator like this?
Old Jun 8, 2015 | 02:52 PM
crowz's Avatar
crowz
http://www.superchevy.com/how-to/vem...tallation.html
I cant find anything about straps anywhere but the above article might help is some ways.
Old Jun 8, 2015 | 02:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sorry for the slow reply.
'92 LT1. Radiator is for "1990 -1996 Corvette". Thanks for the pics and link. I'll read it now...
Old Jun 8, 2015 | 03:06 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Yep. great link. That cleared it right up! Foam top and bottom, plastic straps for shimming any gap between the fans and the shroud. Thanks!
Old Jun 8, 2015 | 03:09 PM
crowz's Avatar
crowz
Cool. Now take LOTS of pics for when I do mine
Old Jun 8, 2015 | 04:13 PM
enventr's Avatar
enventr
That's exactly how my foam was on top and bottom. I also used the 2 spacer bars (metal) to allow for the thicker radiator. 95 vert.
Old Jun 8, 2015 | 06:54 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sorry, no pics of the re-assembly...it's done already. Pics of disassembly HERE. though, if interested.
One thing about the DeWitts that annoyed my a litttle; the new, longer screws are to accommodate the spacer for along the top of radiator. Unfortunately, they are course thread (like wood screws thread) and don't work w/the threaded speed nuts on the shroud. Assuming the the speed nuts were this style (not threaded):
...I merrily started tightening...and twisted /cracked my shroud. Grrrr. The speed nuts in the shroud are this style:
...and require a fine threaded, metric bolt. So, heads up there.
Also, If I were doing it again, I'd probably trim the foam, as it is much thicker than it needs to be, requiring the "smashing" of it, to make it fit in, under the shroud. Otherwise, the radiator itself does fit sweet, and looks fine (stock) all installed. Looking forward to another 23 years of good service from it!
Old Jun 8, 2015 | 08:07 PM
crowz's Avatar
crowz
Its on my todo list just other things in front of that step.
Congrats though.
Old Jun 9, 2015 | 12:02 PM
jimpay's Avatar
jimpay
Cruising
Talk about timing! My new DeWitts is in the garage getting ready for installation next week on my '93 coupe. Really appreciate all your guidance.
Old Jun 9, 2015 | 02:21 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Jun 9, 2015 | 03:21 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Thanks for the excellent post Pete! I wish mine would have come w/directions. This....
...would have been a big help.
Old Jun 9, 2015 | 05:01 PM
PLRX's Avatar
PLRX
2017 C4 of Year
That was wrong, no way to modify or to install a aftermarket part into any car without proper instructions.
Old Jun 10, 2015 | 07:32 AM
856SPEED's Avatar
856SPEED
Yes, surprised; as much hype as I have seen for DeWitts on here, NO DIRECTIONS????
Good work from the forum members......
Old Jun 10, 2015 | 07:40 AM
Joe C's Avatar
Joe C
To DeWitts users, Step in please....
