Youre thoughts
Old Jun 20, 2015 | 02:00 AM
Ziggy*'s Avatar
Ziggy*
Default Youre thoughts
90coupe, 86 vert, 84 beater truck . all on R 12....Been doing the math , to change just the vette's over to 134 (flush, new "o" rings,hoses, aculumator????, draw down the system....Like to keep 'em stock...I am a card holder for HVAC.....Here I come Fleabay....Going to eat hotdogs for a month paying for somebody's lucky find.....
Old Jun 20, 2015 | 05:02 AM
kg4fku's Avatar
kg4fku
Thoughts on what?
Old Jun 20, 2015 | 05:09 AM
crowz's Avatar
crowz
$30 conversion kit.
No vacuuming it down, no oring changes, just use the kit and enjoy the a/c.
Old Jun 20, 2015 | 05:53 AM
nicpete's Avatar
nicpete
Originally Posted by crowz
$30 conversion kit.
where can you get the kit ? and its really that simple
thanks
Old Jun 20, 2015 | 06:14 AM
crowz's Avatar
crowz
Yep its really that simple.
Napa has it and I have bought them at autozone before.
Comes with everything you need. Freon with oil converter added, hoses, adapter fittings, etc.
Old Jun 20, 2015 | 07:40 AM
antfarmer2's Avatar
antfarmer2
Just get the freon replacement $50 a case
Old Jun 20, 2015 | 11:09 AM
Ziggy*'s Avatar
Ziggy*
The two different types of oil are not compatible. Searching the old threads, I gather, To do it right, you have to flush the system, change the accumulator/ drier, meaning you have to break open the system. You can reuse the old "o" rings an hoses, but they will leak. Don't want to throw a quick fix to it, Then the compressor locks up snapping my belt an me sittin by the road. The "Freeze 12" they sell on fleabay is propane based. Don't really like the thought of that under a fiberglass hood. Thanks
Old Jun 20, 2015 | 11:32 AM
crowz's Avatar
crowz
Ive done honestly over 100 of them and no you don't have to change it out. Kit works fine.
The whatever/12 alternatives normally are very flammable and quite dangerous. They do work but so does playing Russian roulette.
The 134a conversion kits work fine.
Old Jun 20, 2015 | 11:35 AM
crowz's Avatar
crowz
Oh and notice I said "CONVERSION KIT" and not just put Freon in it.
The kit comes with the oil additive in the Freon to convert it over and not eat the system up. If you just put regular 134a in there it will damage the system. Once the kits been used you can use cans of regular 134a if you need to top it off later on.
Old Jun 20, 2015 | 11:45 AM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
I used the kit about 2 months ago in my 91 ZR-1 works fine, follow instructions you'll be fine.
Old Jun 22, 2015 | 10:23 AM
HGUNHNTR's Avatar
HGUNHNTR
I'm more than thoughts.
Old Jun 22, 2015 | 11:07 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I had my 91 converted a few years ago, I find it does not cool as well.
Old Jun 22, 2015 | 11:14 AM
ovrebo1's Avatar
ovrebo1
I switched to R134A and all I did was buy the little screw on connectors, vacuum the system and fill it up with the new refrigerant. Works fine. I talked to a A/C guy who said he's done 100's like that and anyone telling you, you can't is just splitting hairs
Old Jun 23, 2015 | 12:59 AM
Cliff Harris's Avatar
Cliff Harris
Keep in mind that the earlier cars (like before 1988) don't have a "barrier" lining in the hoses and the R-134a will leak out much faster than a proper hose (the molecules are smaller than R-12).
Old Jun 26, 2015 | 02:23 PM
Ziggy*'s Avatar
Ziggy*
Thank you Cliff, Your old posts are the ones I was looking at. I'm going to bite the bullet an see if I can get a couple of small cans of R12 to get me through the summer. Then redo the system over winter on the 86 Vert. Just can't handle the heat like I used to. Hot day, sitting in garage on rocking chair, adult beverage, watching the grass grow...lol Thank you
Old Jun 26, 2015 | 09:55 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I bought the 134A conversion kit for my 85 at Walmart over 10 years ago. Has blown cold ever since
Old Jun 28, 2015 | 01:24 AM
Cliff Harris
An interesting thing has happened in regard to R-12. When it was first banned a lot of people started hoarding cans of R-12. Now that most cars run R-134a or have been converted to R-134a, these guys are "stuck" with R-12 that nobody wants. The prices have come WAY down.
To Youre thoughts
