L98 Value
Old Jun 21, 2015 | 02:45 PM
ZCarr's Avatar
ZCarr
Default L98 Value
I have a 91 that i purchased to restore. The car had bad head gaskets and i would prefer to rebuild the engine rather than chance running with the bearings that are in the car. I found a 91 being parted out on Craigslist. For a~50k motor what do you think it's worth. I thought it would be nice to drop something in while i rebuild the original.
Old Jun 21, 2015 | 02:48 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
How many miles on original engine?
Old Jun 21, 2015 | 04:34 PM
ZCarr's Avatar
ZCarr
76k
Old Jun 21, 2015 | 05:42 PM
jay1055's Avatar
jay1055
Default Engine
76k
If it was me I would rebuild instead of replace if you are keeping the car. If you are not going to keep it than replacing my be cheaper. Jay
Old Jun 21, 2015 | 05:56 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
He said he's rebuilding and wants to put in an engine while rebuilding.
$750-$1200
but I'd want to see it being run on a stand.
Old Jun 21, 2015 | 06:06 PM
Kevova's Avatar
Kevova
Engines from private parties have a element of risk, generally " as is" I wouldn't want to have more than 750.00 in it. Would pay 1200 to 1500 with a warranty in writing. I would also want to inspect bottom end prior to taking it. You have to have the money when you show up. If not it sours the deal.
Cruisinfanatic
76k
whats wrong with that mileage unless you plan on wearing it out in the future? I'd just fix the gaskets and be done
Old Jun 21, 2015 | 10:25 PM
ZCarr's Avatar
ZCarr
I just wanted to throw a cheap motor i while I rebuild. Rebuilding gets out of control really quickly. Motor is so annoying to remove that you might as well make sure it is perfect line bore, home ect. Then I might as well buy forged pistons for durability and if you have forged pistons you don't want to use the factory rods so now it's forged pistons and a set of 1000 dollar Oliver rods. Forged pistons and rods then you need a cam which requires a tune. You get a cam you need an exhaust. It just never ends and costs a fortune and takes a year.
Old Jun 21, 2015 | 10:32 PM
VikingTrad3r
Oil Producer
a realist. i like the way you think.
i think your plan is a good one. running the temp engine on a stand, starting from COLD so you can see if valve are shot, with a stethescope and a compression tester should tell you if the engine is shot.
Old Jun 22, 2015 | 08:47 AM
ghoastrider1's Avatar
ghoastrider1
swapping in a used engine gives you the best of both worlds. You can drive and work on the other engine as time, money and the "wanna do it" comes in line.
To L98 Value
