Minor chip modification
Old Jul 6, 2015 | 03:58 PM
mlm0's Avatar
mlm0
Default Minor chip modification
Meant to say modification
1989 L98 with auto transmission
Stock except K&N filter and Bouch lll injectors, 49000 miles
Looking for someone experienced and who would be willing to burn new chip for me
All I am looking to change are:
Fan come on sooner
Delete vats
And I would like my RPM at idle set just a shade higher
Willing to pay
Mike
Old Jul 6, 2015 | 09:48 PM
CREWZIN's Avatar
CREWZIN
Had a custom chip made for my 87 a few years back from The CORVETTE CONSULTANT
Performance Enhancements for Corvettes and Camaros
P.O. Box 2126, Montauk NY 11954
Tel: 516-668-5780
Don't know if they are still in the business. Did wonders for my Vette. Passing gear was the biggest change that I noticed. Throws you back into the seat and jumps like a scarred rabbit.
Hardest part was lying on my head in the passenger seat trying to take the computer out to change the chip.
Old Jul 6, 2015 | 11:31 PM
Patsgarage's Avatar
Patsgarage
I can't help with the fans or the vats issue, but you can raise the idle manually by screwing out the stop on the throttle plate.
Old Jul 6, 2015 | 11:51 PM
mlm0's Avatar
mlm0
my understanding is that the ecu controls the idle speed and just screwing in the idle stop will mess up minimum idle speed and the IAC setting. Am I wrong?
Old Jul 7, 2015 | 12:11 AM
Patsgarage's Avatar
Patsgarage
I don't think so, but I could be wrong. I have had to do this the last few times to get mine through inspection. I just tweak it 1/2 turn or so, just enough to raise the idle by around 100 or so RPM. I do not drive it for long this way, but I never noticed any problems.
Old Jul 7, 2015 | 11:51 AM
jimmers's Avatar
jimmers
Correct. There is a procedure to set the minimum idle.
https://www.corvetteforum.com/forums...dle-speed.html
To Minor chip modification
