Fluid temps ?
Old Jul 13, 2015 | 12:11 PM
JWASR64's Avatar
JWASR64
Default Fluid temps ?
What are the expected temps with outside temp @ 92 degrees
coolant -
oil temp -
oil pres. -
Thank You !!
Old Jul 13, 2015 | 12:33 PM
PatternDayTrader's Avatar
PatternDayTrader
coolant -
oil temp -
oil pres. -
Thank You !!
After a hot soak such as 20 mi at highway speed.
Coolant = 205
Oil temp = 215
Oil Pressure = 30-40
These are what my 95 lt1 w 46k run at.
Old Jul 13, 2015 | 12:36 PM
84XfireAuto's Avatar
84XfireAuto
coolant -
oil temp -
oil pres. -
Thank You !!
Mine is about ....
coolant - 205 to 210
oil temp - 220 to 230
oil pres. - 50lbs @ idle - 65+lbs @ cruise
Mine is an L83 with 117k
Old Jul 13, 2015 | 12:41 PM
JWASR64's Avatar
JWASR64
Thank You for the info.
Amotoxracer, that is about what saw after similar hwy driving.
1995 LT1
Old Jul 13, 2015 | 01:25 PM
cuengineer's Avatar
cuengineer
My '88 with L98 engine after it is warmed good runs
Coolant - 198-203
Oil temp - 215-220
Oil pres - 36psi @ idel, 48 psi @ 60 mph
Old Jul 14, 2015 | 06:18 PM
DGXR's Avatar
DGXR
My cruising temperatures are about the same regardless of the ambient temperature (note, I just did a full cooling system flush, 50/50 with coolant enhancer):
coolant temp 194-198 F
oil temp 205-215 F
oil pressure between 40-50lbs anywhere around 2000rpm
To Fluid temps ?
