84 mod question
Here is my question. I want to know if replacing the injection system with a different intake and mechanical carb is a valid idea?
Am I opening a huge can of worms by doing so. (computer, dash....etc...)
And,
Thanks!
Shawn
Shawn
I'm planning on putting a Renegade intake on my 1984... that alone is supposed to be good for 20HP according to the advertising. If you've seen the runner size in the stock Cross-Fire intake you'd see why. The Renegade is as far as I know the only replacement Cross-Fire compatible intake currently being made, the others like the X-Ram aren't in any of the catalogs anymore.
I'm planning to go a little further than that though, I am planning on also replacing the stock smog heads with aluminum heads with 64cc chambers, 180cc intake ports and 2.02" intake valves, swapping the stock flat tappet cam, lifters and stamped rocker arms for a retrofit hydraulic roller setup with roller rockers and a double roller timing set. I will also install headers to complement the cat-back exhaust system that is already on the car. I already have a Super 65k HEI distributor and a new set of 8.8mm Accell plug wires I plan to put on. At some point if it needs it i may get my throttle bodies bored to 2", have 68lb/hr injectors installed and upgrade the ECM to a newer/faster one...
Anyway, I'm hoping that all that together will get me up to around 250 HP or so... that should at least make me competitive with L98 Vettes with TPI. I have no illusions it will make it hang with an LT1 car, let alone a C5 or newer... but it should be a big improvement.
I would not change to a carb, I personally feel like it is going backwards. Crossfire cars are dependable and deliver good mileage.
I do find the TBI setup mentioned above an interesting alternative. I have a 92 GMC truck with TBI and I like how it runs.
Shawn
L83 Mods:
*Ported intake
*No cats
*Converter
*free tuning (fuel pressure, base timing)
LT1's Mods
*Long tubes
*Exhaust
*52mm TB
*License plate CAI
*Gears
LT1 in the close lane, CFI, far lane. W/regard to the numbers, keep in mind this is in UT; 4500' elevation and likely a ~7000' DA. That CFI car would go 13's at sea level, w/all stock long block. RIP, CFI-EFI.
L83 Mods:
*Ported intake
*No cats
*Converter
LT1's Mods
*Long tubes
*Exhaust
*52mm TB
*License plate CAI
*Gears
CurtisVsJim - YouTube
1. tuning (timing) is incredibly conservative on all CFI motors, and large gains can be seen from nothing other than base timing increase.
2. The PORTED intake (or Renegade) has a reasonable runner cross section (the major handicap of the stock engine), but does NOT have a long runner design that hurts high RPM power, so you end up with a decent cross section and a nice, mid-length runner intake (think HSR length) with a great RPM range.
Here is a personal example: MY CFI car was an '83 Trans Am, so it had only a 305 (CFI). With these mods:
*Edelbrock "headers" and Y
*Increased fuel pressure (on the stock pump)
*Advanced base timing
*160 stat
*Electric fan
*smog pump removed
*T-5 trans (car was originally an auto)
...the car went 14.5/95. How many hp does it take to get a ~3400 lbs car to go 14.5/95? About 230 or so (remember, 305). My car was originally rated at 170, so that is pretty strong evidence that a little tuning goes a long way on the CFI set up.
With a slight timing advance over the factory setting, I noticed an immediate increase in not only acceleration, but also throttle response and gas mileage.
So many people have hate for the CFI cars, I wonder how many have actually owned one?
Copy you on your expectations, and that makes some sense. Definitely better to be happily surprised than to be disappointed.
The CFI give up 95 HP, and a boat load of technology vs the LT-1.
If you want LT-1 performance, just buy an LT-1 Vette, or Camaro/Firebird if funds dont allow a LT-1 Vette.
By the time you buy the CFI Vette and spend the money needed mod it to 300+ HP, you could have bought a LT-1 car.
I love my CFI Vette, and I know and accept its limitations.
When the time comes that I tire of it, I'll sell it and purchase a newer, faster Vette.
But the one thing I wont do is hack up a classic Vette because its "not what I want".
I got my CFI car (which remember, started as a 305) to just about 300hp for around $1500. Want the parts/price list? For ME, that included changing the engine, since I was starting w/a 305, not a 350. Admittedly, I used a lot of used/junk yard parts, but it all worked out nice, and it ran for a long time for me, before I sold it. This was 15 - 20 years ago, so parts may have been cheaper, but it was also back when people were plowing new ground w/CFI, and many still believed that you couldn't port the intake b/c you'd lose all your low end tq.
Getting to ~300 hp should be attainable with intake/intake porting, heads/head porting, exhaust, injectors, cam and tuning. Been done enough times, that there shouldn't be a "mystery" to it. Viewed another way, it should take the same thing it would take w/an L98, minus the ~$1000 required to spend to "fix" the L98 intake.
To me though, it just isn’t worth the investment.
Id rather enjoy my car as is, rather than chop it up for the sake of a few more ponies.
I don’t take my car to the track, and my street racing days are long behind me.
So why do I need to butcher a classic car just for the sake of more power?
My L83 makes more than I can use on the street (sanely) as it is.
But thats just me, Im sure others feel differently.
And yeah, the mods I have planned will not be cheap... but around here a 1984 is so much cheaper than even a 1985 usually (in the same condition, similar miles) that I'm not really that much over where I'd have been had I started with a L98 car. And LT1 C4s around here are usually that much more expensive than an L98 too...
