How in the HELL....
Old Aug 6, 2015 | 11:12 AM
Klondike's Avatar
Klondike
Default How in the HELL....
do you get plugs 6&8 changed in an LT1 or LT4? Any tricks I might be unaware of? I know I did it once when I was younger and more tolerant than the grumpy impatient bastard I am now. The dipstick is right in the way and I think it must be welded in there. Can't for the life of me remember how I got my hands in there last time. I MUST be much larger now than I was 3 Opti's ago! It fowled the plugs this time and the ones I got out so far need changing anyway. I might be able to pop the wire off #6 from underneath with a long screwdriver because I can see the edge of it over the cat & starter, but......
The fun to ratio has gone past the tipping point!
Old Aug 6, 2015 | 11:25 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I've had luck with a spark-plug socket (The type you can put a wrench on) and open end wrench and of coarse some blood and sweat!! You can also remove the inner wheel well panels.
Old Aug 6, 2015 | 11:42 AM
Paul Workman's Avatar
Paul Workman
As I recall on my 95 LT1, the easiest time I had (especially w/ #8) was to access it from underneath the car. I also read that removing the AC housing was one way to access the #8 from above, but I never tried that.
As for the sparkplug socket with a wrench hex top, that too has done the trick several times for me as well.
(Just ONE of the advantages to the LT5 is getting to the friggin spark plugs...NO PROBLEM!)
Old Aug 6, 2015 | 11:56 AM
kg4fku's Avatar
kg4fku
The easiest way is to remove the inner fender well pieces and tire. Then use an extension, a universal joint extension and spark plug socket to remove and replace those two plugs. The same is true for the opposite side.
The fastest way is to use a regular deep well socket and good, slender ratchet and a lot of flowery words.
Old Aug 6, 2015 | 12:02 PM
WVZR-1's Avatar
WVZR-1
#8 on the LT5 has it's own set of circumstances but correct sockets, extensions etc. make that very doable also. I believe the removal of the AC case is mentioned for access also. I took a plug socket and cut it short on the spark plug end for sure and that I believe made it a drop-in that an extremely short extension and premium ratchet made work.
On the LT1 I believe the wheel-house panel removal would certainly be a first move.
A V8 Monza was a challenge for sure. It's been a very long while but I believe I recall a fellow that used a 'hole-saw' and cap-plugs the first time.
Old Aug 6, 2015 | 04:41 PM
Klondike's Avatar
Klondike
Well, I got tired of screwing around trying to go around stuff. I pulled off that air pipe that goes from the back of the manifold to the exhaust manifold. That was an adventure in itself. Then removed those pesky little wire loom holders and it really opened up the area. Plugs are now all out. Next rodeo is getting that stiff hose for the compression tester in there! Just got 4 holes checked so far and it got too hot in the garage to do any more today.Those checked OK. Hoping I didn't wash out the rings when the Opti went bad. I was out in the desert, no cell service, so I had to crip it back to civilization where I could call a trailer. It went through a tank of gas in 100 miles. It was pig rich and stinking of gas when I shut it down.
Old Aug 6, 2015 | 06:24 PM
antfarmer2's Avatar
antfarmer2
I found a wratchet at walmart that will work as a regular wratchet or you can twist the handle to work it once it's loose $20
Old Aug 6, 2015 | 06:35 PM
RUU's Avatar
RUU
You quite likely killed your O2 sensors if you ran it that rich for that long.
Old Aug 6, 2015 | 06:49 PM
Klondike's Avatar
Klondike
That's what I've been thinking too, but I had my scanner in the car with me when all this went down and I plugged it in while driving back to civilization. The only codes I got were random and multiple misfires from opti. No other codes showed up. Plugs were pretty sooty and the exhaust tips were black and stinky. We'll see when I get it all back together. I'm hoping I didn't ruin it. Don't think I can afford a rebuild right now.
To How in the HELL....
