pic request - 85 corvette - original plug wire routing
anybody have a low mileage 85 with original spark plug wires and routing? any chance of posting a couple pics? I'm getting into routing the wires, but the 85's FSM routing seems to be different than later year L98's - some wires route in front of the distributor, whereas later years are behind the distributor. wondering if there is a typo in the FSM - ??? TIA -
https://www.corvetteforum.com/forums...post1586926103
I believe Cliff's is a CI '86 and he made comments in that same thread. He purchased his NEW as did Ray Quayle and I believe Ray's is also a CI '86 but certainly not sure. Ask Ray?
Does your FSM show a carb also?
Where are the snapshots/images you had in this thread?
I saw that the FSM required the #2 and #3 wires to go in front of the distributor, but they couldn't go that way because there wasn't enough space between the rear of the plenum and the distributor cap. Mine came from the factory with the wires behind the distributor cap.
The brake booster vacuum port at the intake rear and the fuel supply on the RH front certainly "hint" L83 Cross-Fire.
I might have to revisit an earlier FSM. Your '85 looms and supports on your '85 should be just like the '90 FSM. I would imagine the '91 is incorrect also. A fellow asked about the '89 rear supports on the cylinder heads some time ago and I mentioned this. He finally just caved and fabricated something I believe.
In your '90 FSM check 6D4-7
From an '84 FSM:
