steering knuckle replacement question
Old Aug 13, 2015 | 05:52 PM
crxnug's Avatar
crxnug
Default steering knuckle replacement question
im in the process of replacing the steering knuckle in my steering column, can anyone tell me how to remove the spring , not sure how to remove the spring for the tilt mechanism , ny help would be much appreciated
Old Aug 13, 2015 | 08:52 PM
WVZR-1's Avatar
WVZR-1
Using an appropriately sized flat blade screwdriver, depress and twist counter clock-wise a quarter of a turn. The spring will exit the knuckle half facing you.
Old Aug 14, 2015 | 07:45 AM
crxnug's Avatar
crxnug
i tried turning it so hard im afraid of stripping it, is there anything else thats preventing it from turning
Old Aug 14, 2015 | 07:59 AM
WVZR-1's Avatar
WVZR-1
You didn't depress it then. It should be "effortless", well maybe nearly LOL
Old Aug 14, 2015 | 09:03 AM
byynow's Avatar
byynow
Also, put the column in the most "up" position. That relieves some of the spring tension. As memory serves me, I remember that a 1/4" drive extension will fit the square hole and with a ratchet, will give you something that is easier to push.
Old Aug 15, 2015 | 03:36 PM
crxnug's Avatar
crxnug
put steering column up and spring came out no problem, just have to get the pins out, not sure if i will buy a puller, i went to a couple places and didnt have what i would need or just make something up to pull the pins
Old Aug 15, 2015 | 04:30 PM
WVZR-1's Avatar
WVZR-1
Try a 10/32 thread in the pin, I don't recall the thread but that's best I recall and first that came to mind. If that's it then it's very straight forward to create the puller required. I'll leave you to figure out the "creativity" required.
Old Aug 15, 2015 | 10:02 PM
reg_255's Avatar
reg_255
CRXNUG,
Did you remove the column?
Just wondering, I need to do this too.
Roy
Old Aug 17, 2015 | 09:37 AM
byynow's Avatar
byynow
Originally Posted by reg_255
CRXNUG,
Roy
Yes, at this point you need to remove the column. That is so you can remove the lower shaft, to replace the knuckle. I do hope you have invested in a Factory Service Manual. It will be of great help.
To steering knuckle replacement question
