Dana 44
Old 08-31-2015, 07:10 PM
TC233
CF Senior Fox Bat
Support Corvetteforum!
TC233's Avatar
Default Dana 44
Is there a way to determine whether a C4 has a Dana44 or 36 from its VIN #?
If Not, was there a certain engine size or tranny combo that would tell you?
Thanks for any help
Old 08-31-2015, 07:12 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
1984 = All were D36
1985 - 1996: Automatic = D36, Manual = D44
Old 08-31-2015, 07:23 PM
pologreen1
pologreen1's Avatar
You can't tell from the vin really but there should be a tag on the rear end, plus if the PO swapped one in like I did you won't know. You can google images to see the differences.
Old 08-31-2015, 07:25 PM
corvetteronw
corvetteronw's Avatar
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Be aware that some owners will swap out a D36 for a D44 though.
Old 08-31-2015, 07:40 PM
TC233
CF Senior Fox Bat
TC233's Avatar
Originally Posted by RollaMo-LT4
1984 = All were D36
Engine size change that at all?
I am finding I can buy a very high mileage junker C4 thats not exactly "cherry" and get alot of parts for my 63 restomod and spend less then looking for suspensions only and then pay the shipping
So if it runs no shipping lol
Old 08-31-2015, 07:52 PM
WVZR-1
WVZR-1's Avatar
Received 2,270 Likes on 2,031 Posts
As mentioned a manual trans car would have the D44 unless already removed and sold! Happens. Through '88 the rear gear would be a 3.07, an '89 early car a 3.54, later '89 3.33, '90 a 3.33 unless a ZR-1 then 3.45, '91+ are 3.45 but there's reported 3.54's.
If you're wanting complete suspensions you need to know what chassis your using would like. '87 and earlier are substantially different.
Old 08-31-2015, 07:57 PM
crowz
crowz's Avatar
Or you can get lucky and run across something like my 87 automatic convertible had put in it. D44 with 3.73 gears
Old 08-31-2015, 08:28 PM
TC233
CF Senior Fox Bat
TC233's Avatar
Doing an SRiii chassis made for a C4
Old 09-01-2015, 03:55 AM
WVZR-1
WVZR-1's Avatar
I would think if doing SRiii then you want to limit your search to '88+ cars so that you can use the front components and the D44 with the L/R suspension units with caliper controlled/activated e-brake.
Do you have the SRiii yet or just planning? They'll let you know which and unless specified differently I believe they intention '88+ components.
To Dana 44
Quick Reply: Dana 44
