94 a/c issue
Old Sep 30, 2015 | 09:04 PM
antfarmer2's Avatar
antfarmer2
Originally Posted by jframe
Checked it today by jumping the connector that hooks to the low pressure switch. When I did that, the compressor kicked on when I started the car and turned it on. However, the air never got cold. Does this indicate a leak AND a bad switch as well?
do not run it with the switch jumped that is just to test. did you spit in the valves yet? sounds like your just low on freon. $5 fix
Old Nov 10, 2015 | 08:55 PM
jframe's Avatar
jframe
Updating this thread; had the HVAC checked today. They ran dye thru the system, evacuated and charged it, and found a service port leaking. Several of y'all, namely antfarmer, said this could be the issue. Fixed the valve, recharged, and all is well so far. I know you don't need A/C much in November, but you DO need a defroster, and I'm just proud to have it fixed. Thanks for all the suggestions and hints.
Old Nov 10, 2015 | 09:03 PM
antfarmer2's Avatar
antfarmer2
good job
