Update
Dash is working and I have wipers. While replacing all the fuses I noticed the fuse box wiggling slightly I turned the key on and wiggled the bundle of wires going to it and everything started working. I need to go through and make sure the wires are secure and have a tight fit but glad I found the issue. Thanks for all the help. not too shabby for a $1500 vette
Yikes !! that's kind of not good. I hope for your sake the backside of the fusebox is not all green with corrosion from water damage. If that ends up being the case then any of the various electrical circuits can (and probably will) quit at any time. At least your gaining on it though ....
