I think I have a pretty good understanding of the leaks in our cars, but was wondering...if one of the drain tubes gets full of debris and backs the water up, where and how does the water get in? The all originate at the cowl where the windshield wipers are mounted to the body. I know there is one on the passenger side that when clogged dumps water in the passenger side footwell... Anybody ever traced the flow?
Water leaks are a pain. For water to enter through HVAC opening at cowl it normally takes a lot of rain. The car would have to be parked under trees or source of flying debris regularly. Cowl will likely hold a couple gallons of water, never measured it. Water level would exceed dam designed to prevent water from entering HVAC case.
So what your saying...the clogged tube then stops the flow and it backs up and fills the cowl up with water and then it leaks in through the HVAC? I agree that would be a ton of water.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
What is more disturbing is the drain tube in the left rear side of the fuel filler bib. It can become clogged up from debris and spider crud. If you get caught in the rain the water can pool and get sucked into your fuel tank. Learned this at a Gordon Killebrew C4 class.
Good idea to run a wire down there from time to time in order to clean it out.
besides keeping the drain tubes in the cowl area open and free flowing, the "drain of last resort" is the much larger one on the bottom of the evaporator housing; remove the "gill" on the passenger's side, (same as removing the "gill" on the drivers side to access the battery) and the drain tube is easily accessible.
