Agruments Settled
Old Dec 1, 2015 | 09:09 PM
93Rubie's Avatar
93Rubie
Default Agruments Settled
Straight off the Forums main page.
Make these Myths can die now.
https://www.corvetteforum.com/articl...orvette-myths/
Old Dec 1, 2015 | 09:17 PM
DanielRicany's Avatar
DanielRicany
Well, a high flow water pump cured my problem that I was having. During full throttle runs the engine get to 238 really quickly. Also, cruising at 3500 RPMs on the highway would cause the engine temp to climb up higher until I installed the high flow pump.
And as for the thermostat, I drilled holes in mine to allow the system to bleed off air to the radiator cap quicker.
Old Dec 1, 2015 | 10:42 PM
pologreen1's Avatar
pologreen1
what is you gear ratio?
Old Dec 1, 2015 | 11:10 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
That's intended for C3s, but regarding the 1/8" hole in the thermostat, most the stats come with it now.
The hole helps to burp the system it got NOTHING to do with cooling. On the LT1 (92-96) there is a blleding screw at the 'stat's neck. I guess the GM engineers thought a "hole" was a good idea. ...and it is
The 160°F 'stat does make the engine cooler. I know this by personal experience, and last September it cooled The Ghost so low, that I bought and installed a 180°F 'stat while I was driving thru Tennessee.
I've read few L98 threads in here with positive comments regarding high volume water pumps.
Regarding the timing, and EGR
Old Dec 1, 2015 | 11:32 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Who wrote the article? #3 is dead asssed wrong.
#2 is "marginally" correct. In reality, the answer to that question is; It depends on the capacity of your cooling system, ambient air temp and air volume through the radiator.
EDIT: OMG!!! "Toobroketoretire" wrote that crap!? No wonder it was bogus! That guy is one of the biggest on the forums!
Old Dec 2, 2015 | 08:51 AM
arbee's Avatar
arbee
https://www.flowkoolerwaterpumps.com/cooling_faq.html
Old Dec 2, 2015 | 09:33 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
And from another source:
Stewart Components
More information available on the subject if you search for hydronic HVAC systems, too.
Old Dec 2, 2015 | 10:57 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Probably a new standard pump would have done the same thing.
Stabilized engine temps are dependent upon several things: size of the radiator, the temperature of the air flowing through it, and the amount of heat being produced by the engine.
Now, maintenance things like bad impellers, blocked/plugged radiators, low coolant, etc. of course will contribute to high temps, but the speed of coolant flow (unless it is near zero) in a sound system is not one of them. High flow pumps just pump coolant faster, since the internal volume of the system is fixed.
Old Dec 2, 2015 | 11:18 AM
DanielRicany
I doubt it. The water pump was not faulty. When I installed my AFR 195 Eliminator heads, I was having problems with it running hot. Changed radiator, thermostat, and the water pump.
It would get to near overheating temp just by driving around normally. I changed to a performance radiator good to 600 hp and thermostat to attempt to cure that particular issue to no avail. The cure for that was extensive air bleeding.
Then it would run hot while cruising at 3500 RPMs or higher on the highway and if I made a full throttle run. The cure for that problem was the high flow water pump. Stock pump had no problem keeping up until the new heads.
DanielRicany
3.75:1
Old Dec 2, 2015 | 12:15 PM
John A. Marker's Avatar
John A. Marker
The stat they show in the picture has three holes. I only drill a single 1/16" hole and then position the stat so when the front of the car is jacked up the hole is in front at the highest point. I have a fail-safe stat in my 95 now that should it fail...it will fail OPEN. It already as the hole drilled.
As far as the waterpump is concerned, I put the Flow-Kooler pump on my 85 and it ran 10 degrees cooler.
Old Dec 2, 2015 | 12:37 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Impossible unless you have cooling fans that come on way sooner than designed. If you car wants to run at 190-200, it will regardless of the thermostat you have in
Old Dec 2, 2015 | 12:44 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
What do cooling fans have to do w/anything, when you're moving over 30 mph??
It's absolutely not "Impossible".
Old Dec 2, 2015 | 12:45 PM
MavsAK's Avatar
MavsAK
All a T stat does is set the MINIMUM coolant temperature. Yes, on a cold day a colder tstat car will run colder than one that's identical otherwise, just with a hotter thermostat.
The Radiator's number of passes, surface area, and airflow are the largest factors in determining how well a HEALTHY cooling system functions.
Old Dec 2, 2015 | 12:53 PM
Cruisinfanatic
nothing.
Absolutely impossible. You could have no thermostat and the engine is still going to settle at the cars operating temp. And for a C4, sometimes that's pretty warm
Old Dec 2, 2015 | 12:55 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is right.
HOWEVER, if your radiator has enough capacity, and it should, in most driving conditions, it should be able to drive the coolant temp down "against" the T-stat's opening temp range. Why should it? Cars are designed to be able to maintain acceptable coolant/engine temps in extreme conditions; 100*+F, heavy loads, High RPM, etc. OEM's can't be producing cars that are ok most of the time...but over heat in extreme conditions....well, the current Z06 is facing that very issues and it's "not O.K.".
So with that in mind, most driving conditions are pretty far from extreme; light loads, low RPM, even in high ambient temps, the properly functioning cooling system should have a large margin, with which to "over cool" the engine.
In most driving conditions, your cooling system should be trying to drive your coolant temps right down below T-stat opening point, and in those circumstances, the T-stat would, indeed be "controlling your operating temp".
Old Dec 2, 2015 | 12:59 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
nothing.
So why the comment about fan settings then??
That is dead assed wrong. Read my post above.
I HAVE removed the stat from previous cars, and the car DID run very low temps. In some cases, it would barely get over 100*F.
The car doesn't run ~200*F, "because it wants to". It doesn't "want" anything. It runs at any temp above T-stat fully open, b/c the cooling system's capacity is = to the engine's heat output in those conditions. If "those conditions" for your car are 200* operating temp in "most normal driving", then your cooling system needs attention. MY C4 will run right down against the T-stat in nearly all driving conditions that I encounter; even 95*+F days. In fact, even with it's 180* stat, some times temps will go down as low as ~174*F. How can that be? It can be, b/c the cooling system has way more capacity than the heat the engine is producing...as it should under most driving conditions.
To Agruments Settled
Old Dec 2, 2015 | 01:14 PM
Cruisinfanatic
I think you need a new gauge because a car's cooling system cannot run at 100
If a cars normal high temp is 185-190 or so, having a 160 or 180 will not make a difference
Old Dec 2, 2015 | 01:22 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Please use science to explain why it "cannot". Please keep in mind that what I REALLY said was: In some cases, it would barely get over 100*F. That means it DID get over 100*F, and it was "in some cases", meaning the conditions were right for that situation. But I'd like to hear why that "cannot" happen, technically speaking.
Would you like me to prove you wrong? I'll go pull my stat in my truck right now, video a trip to Salt lake and back, post it. You seem quite certain, for being totally wrong.
Old Dec 2, 2015 | 02:02 PM
Cruisinfanatic
We're not talking about a truck. This is in regard to a C4 which runs hot. I don't care what temp your truck runs at. Doubt anyone else here does either
