We're not talking about a truck. This is in regard to a C4 which runs hot. I don't care what temp your truck runs at. Doubt anyone else here does either
Truck engine, Vette engine, train locomotive engine - no difference. I can assure you that in the middle of January up here where I live, if I were to take out the thermostat totally(which you claim would make no difference) from my 92 and drive down the hiway, it is NOT going to "settle in" to a hot running condition.
nothing.
Absolutely impossible. You could have no thermostat and the engine is still going to settle at the cars operating temp. And for a C4, sometimes that's pretty warm
Not for me,, dead of winter when my Stat stuck open, engine ran @ 135° and My heater was cool..
Bottom line, you need a properly functioning Stat/Radiator/pump. etc.etc. in order to maintain the proper Temperature Margins...
Truck cooling systems function just like 'Vette cooling systems. I know that's hard for people to comprehend...but it's true. Car I experimented w/earlier, that I mentioned "barely got over 100*F, that car was a Trans Am. Trans Am cooling systems work just like 'Vette (and truck) cooling systems also.
You would care...if you cared to learn and understand. It's clear that you don't.
I notice that you never answered any of my questions above. Why is that, I wonder?
*So why the comment about fan settings then??
*Please use science to explain why it "cannot"
*temps will go down as low as ~174*F. How can that be?
arbee and desertmike1 "get it"...you do not. Since you "don't care", then as you were, ignorant though you may be.....
nothing.
I dont know where you get your information, but I got mine from the gauges. Its a fact a 160 Stat will run your engine cooler than a 180.
When is 60°F outside, and the engine is running 159°F on the freeway that is too damn cold for a combustion engine. The engine was acting up, and I knew right then I had to change that thing. Right after I installed the 180°F stat it was in the mid 170'sh. The analog gauge read 185°F.
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Perhaps you have a different SBC.
Not if your car runs hotter than that on a summer day like most stock C4 vettes do . The only difference would be the time it takes to heat up as cold radiator fluid would circulated sooner with lower stat
If the radiator has the capacity to dissipate the heat, it most certainly WILL run cooler with a 160 stat. Engines don't have a temperature that "they want to run" built into them. The engine is designed to run at an optimal temperature and engineering builds the cooling system to support this temperature with a safety factor built in.
As I said earlier; summer day or not, the cooling system should be overkill for most operating conditions...that includes a "summer day". Therefore, properly functioning, the coolant temps should be about the same on a "summer day" as a "winter day". Exceptions would be "extreme conditions"; 100*F+, heavy load, high RPM.
When you post things like "most Corvettes run hot" (as if Corvettes are in some way, special or unique in their running temps -they're not), the essence of that thinking is wrong. Corvettes only "run hot" when they're not properly maintained...which is probably a lot of the C4's that you see, and certainly the majority of those that you read about on here.
A properly maintained C4 should be able to drive the coolant temps down to T-stat opening range, in most "normal driving" conditions...and that does include a "summer day".
Also if you cant get the temp to go lower when you put a lower temp stat in then do a flush and get that orange build up crap out of your cooling system if its stock. After market stuff like heads etc then all bets are off.
Originally Posted by Tom400CFI
^Exactly^.
If you have a 30 year old car and still stock, it will run hotter than new. Lots of threads on this over the years. Some run way too hot, usually because of debris in front of the radiator.
Any build up at all inside of course will effect efficiency of the system. I run a 190 stat with original radiator and rarely do fans go on at 228. Only on really hot day at a light would they. Why anyone wants their car to run at 160 when it's designed to run hotter is beyond me.
I cant answer for most people as to why they want to run at cooler temps but the reason I did that to my 86 had to do with the blower. When I supercharged it I had issues with heat build up under wot.
The more room I had to start with the more I got to play before I had to let it cool back down. Also the cooler it ran the less ping issues I had with it.
That is absolutely UNTRUE, if the car has been properly maintained. You're 0 for 4 in this thread, so far.
Exactly. Not maintained.
That is correct. Hence, the need for maintenance.
Everyone has their ideas or motives. Mine back in the day, in my Trans Am, was that it allowed me to run more timing than I could at a hotter temp. That timing resulted in slightly more power. Track verified. That is ONE reason. EDIT: Same reason as Crowz reason.
nothing.
If this was true, then why would car manufacturer's waste money to make a valve(thermostat) that you deem is essentially unnecessary?
A thermostats main function is to maintain a minimum coolant temperature after the engine has warmed up.
LOL, I knew this would happen. Looks like I was wrong. Don't shoot the messenger. Complain to the author/poster of this article to the main page of CF.
Give up. The C4 has the cooling capacity to run much lower than stock temps, especially if someone has installed an aftermarket radiator, by using a different t-stat.
On a typical 75*-80* day, my 500hp+ 383 with a DeWitts radiator and a 160* t-stat would run in the low to mid 170s all day long on the freeway. If I sat at a stoplight, due to the lack of airflow, it would slooooooowly creep to the 190s but I had to sit there quite awhile. As soon as the car was rolling again *or* I manually turned the fans on, it would cool right back to the 170s. On the racetrack, 30 minute ***** out lapping sessions, I would be around 220.
The t-stat sets the minimum temp. As an aside, the aftermarket 160* stats actually start to open at 160* and are fully open between 175* and 180*. The OEM 180* stat starts to open at 180* and is fully open a little over 190*, hence why a stock LT1/4 C4 run in the low to mid 190s on the freeway.
