Ride Control
If you're talking about the FX3 Blistiens (sp?) ride control, the actuators and shocks are a sought-after system, especially by the ZR-1 community. The shocks can be re-firbished, IIRC, and the actuators can be too. So, if you do replace them with standard shocks, don't throw the FX3 stuff away!
BTW, the FX3 system is somewhat subtle, especially on smooth roads and low speeds. But, on 'less than perfect' roads, and especially at speed, the system is designed to react accordingly. Then the difference - especially from TOUR and PERF settings - is very distinct (or at least mine is!)
Paul.
http://www.captainzcnc.com/index.html
Here's a link showing Bilsteins prices for shock rebuild services -
http://www.bilsteinus.com/products/s...rvice/service/
Their order form with the telephone number to call -
http://www.bilsteinus.com/uploads/tx...sheet_2015.pdf
Here's a link for new shocks -
http://www.corvetteamerica.com/cf/di...ategoryid=X932
Your shocks and maybe your actuators are not operating correctly. I would have both the actuators and shocks rebuilt. When working correctly it is a nice option to have on the car. Plus it was a large selling point when C4s were being built and driven.
If you search, most of the major Corvette vendors usually have the shocks and/or actuators also.
Whatever you decide, good luck to you and the car.
In the future if you are selling your car, the FX system may be a good selling feature.
Tip, the rear actuators are actually in the frame but are very easy to take out by carefully removing the shock absorber.
I'd like to save it but the car is only a good ten footer. Drive it daily when I can. Can I buy the parts to rebuild them myself? I bought the three FSM books and from what I have read I can troubleshoot the system. I will have to check it when I get the books. Also, I guess there is supposed to be a system check light at startup. I don't think I have seen it come on. Can someone post a picture? Maybe a bulb is out.
Not sure what to do now, LOL. I'm gonna have think and weigh out the options.
