Upgrading my headlights
Old Dec 23, 2015 | 04:35 PM
kidbubbles's Avatar
kidbubbles
Originally Posted by Fastnail
Are these a low/high beam lamp? From the pictures on Ebay it looks like it is a single beam lamp only.
Hi and low.
Plus, the reduced number of seams on the face make the lenses look cleaner and different than the run of the mill Sylvania or Wagner lamp.
They are more than adequate for lumen production.
Old Dec 23, 2015 | 05:46 PM
C5 4me's Avatar
C5 4me
Watching this thread.
Old Dec 23, 2015 | 08:55 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by antfarmer2
100/80 I believe your pushing it to far for stock wireing.
All I can say is that I've been using that setup for over ten years with no issues.
Old Dec 23, 2015 | 09:16 PM
antfarmer2's Avatar
antfarmer2
The stock headlamp electrical circuit, using lightweight, high resistance contacts in the switch, 18AWG wire to complete the circuits, and excessively long wire lengths (running from the battery to the dashboard and all the way out to the headlamps), creates excessive voltage drop. These wires are inadequate even for the stock headlamp capsule, much less for higher wattage. Headlight bulb light output is compromised with lower voltage. For example, normal engine-running voltage in a "12-volt" automotive electrical system is around 13.5 volts. At this voltage, halogen headlamp bulbs achieve 100 percent of their design luminous output. When operating voltage drops to 95 percent (12.825v), headlamp bulbs produce only 83 percent of their rated light output. When voltage drops to 90 percent (12.15v), bulb output is only 67 percent of what it should be. And when voltage drops to 85 percent (11.475v), bulb output is a paltry 53 percent of normal! [Source: Hella KG Hueck AG, Germany]
.QUOTE=rocco16;1591176708]All I can say is that I've been using that setup for over ten years with no issues.[/QUOTE]
Old Dec 24, 2015 | 12:11 AM
Cliff Harris's Avatar
Cliff Harris
The light output from an incandescent bulb is proportional to the fourth power of the temperature of the filament. The temperature of the filament is directly proportional to the current flowing through it. When the current drops off the light output decreases dramatically.
When I installed my HID headlights I grounded them directly to the front grounds next to the horns. The power came from the junction block behind the battery.
Old Dec 24, 2015 | 09:30 AM
antfarmer2's Avatar
antfarmer2
