No headlights
Old Jan 16, 2016 | 08:25 PM
jess's Avatar
jess
Default No headlights
Friends
My car is a 95 vette. The headlight doors open but no lights. I put
in a known good headlight switch on the dash is and still no
lights. I've checked the fuses and they look good. Am I missing
something here. Is there a relay somewhere? Any help is appreciated.
Thanks in advance.
Old Jan 16, 2016 | 08:42 PM
antfarmer2's Avatar
antfarmer2
did you look at the fuseable links behind the battery?
Old Jan 16, 2016 | 09:01 PM
jess's Avatar
jess
No I did not. Is that a fusible exclusive for the headlights
Old Jan 16, 2016 | 09:43 PM
antfarmer2's Avatar
antfarmer2
there are many back there on my 94 and clean the jump box connectors yours should be close I believe.
Old Jan 16, 2016 | 09:52 PM
PatternDayTrader's Avatar
PatternDayTrader
Are both of them burned out ?
Old Jan 16, 2016 | 10:23 PM
jess's Avatar
jess
Yes, I have no headlights on either. I checked all the small fuses in the fuse box on the passenger side and the fuse box behind the battery.
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
My thought. They don't last forever
Old Jan 16, 2016 | 10:52 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
If you have no low or high beam, check the connector for the dimmer switch..
Old Jan 16, 2016 | 10:55 PM
jess's Avatar
jess
Ok I will. Thank you
Old Jan 16, 2016 | 10:56 PM
Nowhere Man
I think he needs to try a known working bulb.
Old Jan 16, 2016 | 11:09 PM
antfarmer2's Avatar
antfarmer2
both quit at the same time high and low?
Old Jan 16, 2016 | 11:23 PM
ccrazor's Avatar
ccrazor
If you don't get a high beam light in the instrument cluster, it would also indicate a problem with the dimmer switch.. If you do then check the bulbs..
Old Jan 17, 2016 | 10:15 AM
PatternDayTrader
Or verify with a test light.
To No headlights
