Here's a question
my 84 corvette is sputtering again only when tack goes down when you
almost come to a stop and give it a little gas it will sputter and
I hear a rattle under neith car
I'm waiting on new plugs and wires to come
put new fuel pump factory specs one
I'm trying to get car up so I can see if anything loose
I'm also looking for parts
drivers door handle bezel has light and switches
hood prop bar
steering column parts
seat covers
I'm in Conway sc
Noise could be from cat converter. When you get car up high enough to get under it bang on converter with rubber mallet listen for rattle. Rattles can be hard to find you may need a two people. Someone to sit in car while it runs operating stuff while the other is under car searching for source. Good Luck
