smoke
Old Feb 19, 2016 | 02:03 PM
UserG's Avatar
UserG
Default smoke
I have a 84corvette I replaced valve cover gasket s
Also I found distributor loose snuggled bolt down not too tight.
but I still have oil smoke it's coming up like if standing on passenger
side of car smoke coming up between distributor and valve cover.
Before I found loose distribitor if you pulled out in low tacking it up then coming to a stop
it would smoke a lot
but since snuggled district its not as much
Help
Old Feb 19, 2016 | 04:22 PM
John A. Marker's Avatar
John A. Marker
There is a gasket between the base of the distributor and the intake manifold....may be your issue. I would get some degreaser and clean up this area. Then if you have compressed air, blow it dry. Then start the car and try and find the exact area it is coming from. Are you losing a lot of oil? Check the oil pressure sensor and oil temperature sensor. They both screw into a fitting that comes up from the back of the block to the driver's side of the distributor.
It may also be the rear china wall. But if you seeing less oil since you tightened the distributor....lean toward the distributor.
Old Feb 19, 2016 | 06:28 PM
Hot Rod Roy's Avatar
Hot Rod Roy
If your distributor was not tight, you need to verify that your ignition timing is correct. Let us know if you would like some tips on doing this procedure!
Old Feb 20, 2016 | 06:18 PM
UserG's Avatar
UserG
There's no oil leaking around distributor
trimming think is off
I have oil dripping very little on exhaust on passenger side. ?
Old Feb 20, 2016 | 06:20 PM
UserG's Avatar
UserG
Well don't see oil leaking from distributor
I see some oil dripping on exhaust on passenger side of motor
any ideas
Old Feb 20, 2016 | 08:41 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Valve cover gaskets
Old Feb 23, 2016 | 10:02 AM
2ooo-C5's Avatar
2ooo-C5
Valve cover gaskets
If you had oil coming out of the distributer even with that gasket missing you would have larger issues.
Old Feb 23, 2016 | 06:47 PM
UserG's Avatar
UserG
Well found out oil filter was not tight plus oil pan bolt was little tight I tighten both
and haven't seen any smoke.
My son gets into too much of a rush sometimes
I don't do much work on car my son. Dose
I've been looking for pre 1974 car or ?
im looking for Black pieces for top of both. Door panels and seat covers
And steering column parts
To smoke
