Dirty radiator
Old Mar 5, 2016 | 07:37 PM
94corvetteC4's Avatar
94corvetteC4
Default Dirty radiator
Looks like I'll be pulling my radiator to clean it and the condenser. Looks worse in person than in the pics. Their is some debris sitting in the bottom that you can't see in the pics.
Old Mar 5, 2016 | 07:49 PM
skyhawk50's Avatar
skyhawk50
Yep, one big vacuum cleaner with 4 wheels !!!
Old Mar 5, 2016 | 08:20 PM
enventr's Avatar
enventr
You should be running a little cooler when it's all cleaned up. The radiator is 22 years old and who knows when it was cleaned last
Old Mar 6, 2016 | 12:00 AM
94corvetteC4
If it was ever cleaned.
Old Mar 6, 2016 | 05:49 AM
antfarmer2's Avatar
antfarmer2
Don't get your opti wet.
Old Mar 6, 2016 | 09:51 AM
Paul Workman's Avatar
Paul Workman
I installed a used radiator (free...the price was right) when I repaired my front end. The previous owner had installed a new after-market radiator, as the old one wasn't working to his satisfaction.
Well, while it was out of the car, I pressure-washed it; carefully blowing high pressure through the core from the back side*. Lord! I was astounded at the amount of sand and vegetation material that came out!
I ran it for the past 2 seasons now, and it never got above 205 - the point at which my fans have been programmed (ECM) to come on, and generally ran w/o the fans coming on whenever I was driving.
*Note: Most pressure washers will develop pressure of up to 2k PSI or more. So, one needs to back away so as not to distort the fins or even break any tubes. But, in any case, if contemplating a new radiator because the old one is not working, the old one might just be very dirty. And, I don't think a garden hose has the pressure needed to clean out the junk that is jammed between the tubes among the fins.
Old Mar 6, 2016 | 04:31 PM
Ozzstar's Avatar
Ozzstar
I flushed the outside of the radiator on my '93 almost two years ago. The exterior fins had never been cleaned in 19 years. 57K miles. The temp was running around 215-217 at highway cruising 65 mph. I did not remove the radiator and was very CAREFUL not to get the optispark wet with the garden hose. I found big bugs, cigarette butts, walmart plastic bag and tons on dried old grass, plus dirt. After the cleaning coolant temp is now 200-202 at the same speeds, summer time heat. Have fun - Ozz
Old Mar 6, 2016 | 06:40 PM
1slov6's Avatar
1slov6
I used a piece of brake tubing, bent a 90 in it and connected it to an air hose..It worked great to blow the debris out
Old Mar 6, 2016 | 06:42 PM
94corvetteC4
I have access to some tubing to build one of those. I'll try it.
Old Mar 7, 2016 | 02:39 PM
SJW's Avatar
SJW
Check out this thread that discusses how to minimize the amount of debris gets sucked into the cooling stack of our C4s:
https://www.corvetteforum.com/forums...trategies.html
Live well,
SJW
To Dirty radiator
