Engine flywheel Question
I picked a supposed 87,000 mile 1985 motor/gearbox. I know these Engines have some major differences. But ........ while I get my old motor to where I want it (rebuilt) is it possible to Plop this 85 motor in rather easily..??? I see I might have to swap over intakes and all that jazz...but somebody told me that the 2 piece Rear seal blocks have a differnt flywheel and the 1 piece?
Or could I just bolt up the old flywheel from the 85' car and maybe my clutch from the 87?
Any thoughts?
Thanks!! Great forum, use this for reference all the time!
Any thoughts?
So it sounds like you'd just like to get your car running again asap, for as little money as possible so forget that 85 engine, for the time and money it'd take to get it into the car, you almost certainly can find a decent running engine from a later sedan and just swap it in using the pan and pickup from your 87. Good luck.
So it sounds like you'd just like to get your car running again asap, for as little money as possible so forget that 85 engine, for the time and money it'd take to get it into the car, you almost certainly can find a decent running engine from a later sedan and just swap it in using the pan and pickup from your 87. Good luck.[/QUOT
First off, Thank you for the reply, I surely appreciate it! This 85 Engine is from a corvette, from Pan to Fuel injection....So being it is corvette, would I still need to swap pushrods and such? It does appear the fuel injection ( though at first glance VERY similar) there are some differences. Like there is No input into the Intake for that heat riser pipe....ect.
Maybe I should just have patience and fix it right. The machine shop told me the block is savable...But the machine cost are significant. Plus I'll need pistons and a crank. I wonder if it would be the time to clearence the block for a bigger rotating assembly (383) but the guy at the shop said NO, it'll mess with the computer...but I've done a lot of reading on this site, and it seems like people are able to Hot Rod these engines and still use the TPI...??
OK you have a Manual & dana 36 still starting to add up REAL quick. start out with the basics. and DRIVE!!!!
unless you can guarantee. the 85 has a roller cam. The pushrods are different sizes between flat VS roller setups.
Judging by your comments, and NAME 383 Admiral, I feel you speak of Experience! What are your thoughts on a little more compression, Flat Top Pistons? Maybe small pocket porting a slightly bigger cam to match a possible 10-1 compression?
See I was kinda hoping when I picked this 85 Vette motor, I could just plop it in and use it, till I got my motor fixed....Well and at the time, I wasn't sure it would even be salvageable.
I really don't want to mess with tuning, or burning new chips. But if I can get a few more horsepower for not TOO much more in the building process...i'd definitely consider. My thoughts are, Wow these are awesome cars ( super cars in fact ) and pretty impressive with 240 hp. I thought if I could squeak out 300 hp. THAT would be icing on the cake? Am I "out of line"?
People rebuild what they've got for a variety of reasons, not all of which make economic sense; lol; i.e. originality / matching numbers; a desire for something different, or just the conviction that they can do it better (and sometimes they can and sometimes they don't) but I suspect the biggest reason is to spread costs out over a period of time. If you do go the rebuild route, don't try to re-engineer the entire engine; keep it simple.
Good luck.
do you have a budget In mind for this project? If your budget allows, consider a crate engine, maybe even a new one from GM; start by adding up costs of ALL the machine work and ALL the parts you'll need to replace and a crate engine, even an new GM will start to look Very Affordable, plus you'll get a warranty.
Good luck.
Then I found this 85 Motor and D/N 4 speed, for pretty cheap. I heard it run briefly and bought it. I figured IF my block was shot...A C4 motor is a C4 motor : WRONG. So Yes, my 87 is a one piece Rear, Roller Cam, and slightly differn't fuel injection.
The local Machine looked at my engine, magnafluxed the block, and said it was savable, with a linebore. 1200, plus I'd need a crank, and pistons. So the real ONLY reason to use this is too keep it Numbers matching. I've already found a shortblock from Competition products for 999.95.
So What is my budget? Well.....I was hoping as cheap as possible, but I'm not against putting money into this fine car. I mean, its a low milage 87! Red, 4 speed, New Tires, Clutch and flywheel, all fluids changed...ect. I had this car gone through at the Chevy Garage before my Track Day. I didn't want anything going wrong!! I really wasn't even on it! I cant believe it broke.
The car is pretty new to me, but I really like it. I'll probably keep it for awhile. So If I have to spend 3 grand I will....and I hear what you're saying, by the time, I do what I want...A crate motor is starting to look much more appealing! And you get warrenty!
Its a hard pill to swallow. I can afford it. I just didn't want to spend the money on it, Nor the time, rather be driving it..lol
But do you think 300 Horsepower is out of the question for the computer to handle? I think upping the compression a tad, and a little more bumpstick will provide close to that. I just dont want to mess with the computer. I dont want to spend a lot of money on tuning. Then there is your other cost....Water pump/ ect...
Thanks for your replies guys, always meet the nicest people on these forums.
