1986 corvette max tire width
Old Mar 22, 2016 | 05:38 PM
rennertristan's Avatar
rennertristan
Default 1986 corvette max tire width
I have a stock 1986 vette and was getting new tires and rims and wanted to see what was the widest tire I could do for the front and then for the back
Old Mar 22, 2016 | 05:51 PM
THE 383 admiral's Avatar
THE 383 admiral
the 86 Has a different rim Offset similar to a 4th Gen F-body. F285 - R315's are about as wide as you can get on the 89? - 96 without the tire Grinding. the ABS inner wells. or using spacers.
https://www.corvetteforum.com/forums...set-chart.html
Old Mar 22, 2016 | 06:36 PM
WVZR-1's Avatar
WVZR-1
Tire width of course is related to both the chassis/body and rim widths used.
The charts referenced in #2 can be very deceiving. I would NOT rely on it or even reference it unless you're very familiar with what's going on. It's NOT for a novice for sure.
Only for information and certainly NOT a suggested install:
A 315 on an 17 X 11" @ 36mm offset wheel is the max generally considered for the rear of an '87 and earlier BUT there will be challenges, muffler often interferes and depending on rear axle placement body also.
You asked "widest" and I believe that's actually maybe "foolish"- widest doesn't very often contribute to drivability and handling.
Application wise it's generally thought that a 9.5 - 10.5 wide might be a range for the '87 or earlier with maybe an offset of 38 for the 9.5 and something 45 or very close for the 10.5. That can be tweaked by knowledgeable persons.
To satisfy the diameters required to keep the speedometer/odometer near correct without changing things you need to try and maintain an advertised "loaded rolling diameter" of something near 25.8 maybe considered a max.
Diameter of rim/wheel maters NOT just the diameter of the tire and the width/offset of the wheel.
Old Mar 22, 2016 | 07:35 PM
rrc1962's Avatar
rrc1962
I was thinking about the ZR-1 wheels AFS sells that are made for the early years. 9.5 x 17 on the front and 11 x 17 on the back. The 9.5's have a 38mm offset and the 11's have a 36.5mm offset. They say these are made for the early years but the offset on the 11's doesn't make sense. To get the same front spacing, the offset on the 11's should be more than the 9.5's.
I have a thing about wheel spacing. I can't stand a car that has the tires hanging outside the wheel wells. Uneven spacing is just about as bad. If the 9.5's are spaced to sit nicely inside the wheel wells and evenly spaced all the way around, the 11's would be hanging out a little more than 3/4" more.
I've not seen photos of an early car with the AFS wheels. Maybe it's not noticeable.
To 1986 corvette max tire width
