Clutch
Old Apr 14, 2016 | 03:03 PM
rennertristan's Avatar
rennertristan
Default Clutch
The clutch pedal is really easy to press in aND it won't go into to gear without extreme force and when I try and put it into reverse all it does is grind any ideas on what it is?
Old Apr 14, 2016 | 03:18 PM
jsmn4vu's Avatar
jsmn4vu
Yes, clutch is not disengaging completely. Have you checked the fluid level?
Old Apr 14, 2016 | 03:20 PM
antfarmer2's Avatar
antfarmer2
might need to bleed too. stop tearing up your transmission.
Old Apr 14, 2016 | 04:04 PM
PatternDayTrader's Avatar
PatternDayTrader
Yeah no kidding. Stop trying to drive it until its fixed.
Old Apr 14, 2016 | 04:14 PM
DMITTZ's Avatar
DMITTZ
I addition to likely being low on clutch fluid, you might also have some bad/failing parts in your clutch's hydraulic system. But check the fluid first and report back to us.
Old Apr 15, 2016 | 08:59 AM
rennertristan
Yes the fluid is low and that's because it's leaking
To Clutch
