84 c4 speakers
Old Apr 23, 2016 | 12:11 PM
monte k's Avatar
monte k
Default 84 c4 speakers
Hi
I have a 84 c4 with Bose,
The radio is good and the amps are good but I have a couple of bad speakers
Any one have a good replacement speakers ?
Monte
Old Apr 23, 2016 | 01:01 PM
whalepirot's Avatar
whalepirot
Originally Posted by monte k
Hi
Thanks Monte
I have a set of originals in a cabinet, that worked well when removed some years ago.
You'll want to see if the speakers themselves are bad or the amps, which may need capacitors, as posted in other threads.
Old Apr 23, 2016 | 01:09 PM
monte k's Avatar
monte k
I already done the trouble shooting, it the speakers, I have 2 that are dead
I put a couple of speaker I had here and they work ok , just thought I'd replace them with something new rather than 30 year old speaker, I don't know might be best to go with the original Bose
Monte
QUOTE=whalepirot;1592062012]I have a set of originals in a cabinet, that worked well when removed some years ago.
You'll want to see if the speakers themselves are bad or the amps, which may need capacitors, as posted in other threads. [/QUOTE]
Old Apr 23, 2016 | 01:15 PM
DinoBob's Avatar
DinoBob
Direct replacement for both fit and impedance, how many of you knew the early C4 speaker was sourced from the Bose 901?
http://www.parts-express.com/replacement-speaker-driver-for-bose-901-4-1-2-1-ohm--290-922
To 84 c4 speakers
