C4 bypass surgery
On the '88 C4 i have in SoCal I discovered that the heater was bypassed, which is fine with me, but I have also been told since I live in a consistently warm climate I can bypass the TB too.
Any issues with bypassing both the heater and TB?
Anything to be concerned about w/TB if I get into cold weather?
Are there any performance gains?
C4 awesomeness!
C4 awesomeness!
If you've never driven a car without a heater, you'll hate yourself if your ever stuck in the cold.
If I was to buy a C4 with the heater bypassed, I'd take $1000 off the price.
1. TB coolant bypassed
2. TB airfoil
3. Smooth TB/MAF tube
4. Descreened MAF
5. Relocated MAT sensor
6. AC delete
7. A.I.R. delete
8. Open air box
9. itg free-flow filter
10. 60mm dual exhaust with no boxes or cats
11. Fuel/ignition totally refurbed end to end
12. About 150lbs of dead weight removed.
Just backyard tinkering for me, but my '87 does run very well as I suspect, due to the combination of all these items, but not any single one.
....WW.
C4 awesomeness!
Make sure you post back what your experience is if you do it.
Icing...is the issue the heat is intended to prevent. And, it doesn't have to be below freezing either - humidity, e.g., a cold foggy morning, plays a huge role in concert with low temperature.
So, it is a trade-off between benefit and liability. What practical benefit is gained, and at what cost in terms of detriment.
The ONLY time air density (DA) is a factor in total engine output is at WOT; less than WOT and the motors output is controlled by throttle opening %. And, at WOT, air velocity past the TB (and that includes runners too) is such that there is very little time for heat transfer and therefore little if any practical change in DA occurs as air rushes past the TB.
I live in northern IL, my TB is bypassed, and I occasionally drive in sub-freezing temps, and have had NO issues with TB freeze-up. But, I must add that it was on clear, dry (air) days, i.e., not humid or foggy, etc.
My reasons for bypassing were two:
- I no longer have to drain some coolant to remove the plenum
- The main reason is the ignition module is heat-sinked to the plenum and the plenum temperature runs significantly cooler w/ the TB coolant bypassed.
If someone wrote about a 5-6 hp gain (on an L98 especially) after bypassing the TB, I'd want to see the data before accepting it on face value.
