From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by Bendeco
My Vette has the wires ripped out of the knock sensor and the O2 sensor, so I am assuming it is in open loop. It seems to use more fuel than it should.
What are your expectations of "fuel use"?
Do you have any wiring diagrams to start reconstructing?
Be ready to fight multiple large scale wars on many different fronts at all times. Be man enough for a strategic retreat when your wrong, and fight to the death when you know your right. No matter what, have the courage to stick your neck out if you have something to say.
Your post reads if you can't dazzle them with brilliance baffle them with bullschitt
That's twice in what 3 days ?? You must not value your business very much if this is how you talk to folks who could possibly need your services. Keep it up and I bet some really bad things are in your future.
I NEVER stated a fixed ratio of anykind for A/F. Why did you mention this like I did?To the best of my knowledge my statements are true. IF you have a problem with that then, IDK what to tell you? I made the statement in good faith, no need to call it BS when it isn't or insult me.
My comments in RED.
My intentions were not meant to insult you in any way. My apologies if you took it as such.
my point is that id the o2 is used for BLM operation and is not accurate at 12.5 AFR then prove your claim to me of what controls BLM at WOT? Therefore, id the O2 is not controlling BLM then it defaults to 128 and the % added.
I agree the narrow band 02 is not accurate at 12.5. In fact they only basically read from about 14.0 to 15.0 A/F.
I cannot "prove" the claim about BLM at WOT. To the best of my knowledge it is based on inputs ( as I stated before) just not the 02 and built in ECM programming. It may well be a added % of some kind.
The 128 on the tool display to the best of my knowledge is a default when in open loop. In closed loop we know it can run much higher or lower so it is reasonable to assume under OPEN loop it does the same however not sure how to view this.
ECM's substitute default values all the time if a fault occurs or in open loop. Not uncommon to see them on scan tool or data logger of some kind at all.
Your talking about going into and messing with the basic programming and mapping. Not an area I am well versed in. I never had a reason to be so....
There is also a highway mode where it runs as lean as 16:1 for 60 seconds with 10 seconds in between. this was invoked in all cars though. I'll invoke as requested and if you've done mods I shut it off. Last time someone said WOT was BLM adjustable I didn't have a credible argument and until this was given to me the other day I hadn't put much thought into it. I do tune WOT by reading the o2 for .860 to about .920. Datalogs also give an AFR and I step through them and watch it and make adjusts from that. The mass air cars rock compared to SD. There's no coding that I'm aware of that adjusts during PE or Cliff would call me out? It is my understanding that newer cars that use wideband have this capability but I've never played with OBD2.
