fuel tank imploded
Old May 11, 2016 | 01:01 PM
xkahn's Avatar
xkahn
Cruising
Default fuel tank imploded
I replaced the gas cap on my 85 c4 and half a tank later the tank has imploded.there was no gasket on the old cap. did the new one seal so good it caused this? what should I look for after I replace the tank? what a mess
Old May 11, 2016 | 06:48 PM
93Rubie's Avatar
93Rubie
Pics would be cool. I'd like to see this.
Old May 11, 2016 | 06:55 PM
WVZR-1's Avatar
WVZR-1
It might be interesting to compare!
OP - this might interest you - in comparison to what's seen in this thread what does yours appear to be? Worse, comparable or maybe not as bad as.
https://www.corvetteforum.com/forums...-big-pics.html
Old May 11, 2016 | 07:53 PM
antfarmer2's Avatar
antfarmer2
Wrong cap it is a big pita to replace the tank I would seal the ports and try to gently blow it back out and hope for the best.
Old May 12, 2016 | 01:21 AM
Cliff Harris's Avatar
Cliff Harris
I have heard of people doing that successfully.
Old May 12, 2016 | 01:31 AM
xkahn's Avatar
xkahn
Cruising
Mine looks much worse. Barely able to fuel it as the filler moved so far back. Can't imagine blowing it back into shape as it has collapsed with many sharpe angles. I'll post a pic tomorrow
Old May 12, 2016 | 06:24 AM
antfarmer2's Avatar
antfarmer2
I would sure try nothing to loose. Have you looked into what needs to be done to replace?
To fuel tank imploded
