1987 check engine light
Old Jun 23, 2016 | 03:36 PM
fancygrl68's Avatar
fancygrl68
1st Gear
Default 1987 check engine light
1987 check engine light on when battery disconnected and back on runs for a couple days the light comes back on jumped wires for code only gives a 12 could it be the computer? also speed odometer not reading right since fuel line work was done.
Old Jun 24, 2016 | 12:59 PM
Kevova's Avatar
Kevova
If speedometer works and odometer doesn't or vice versa problem is with cluster. Bad ECM causing a check engine light code 12 is possible but unlikely. Do you have a FSM? I would make sure the ground wires are all clean and tight. The plug wires are at least an inch away from the 4 wire harness going to distributor.
