I'm sorry but going from 1.5rr's to 1.6rr's is not going to gain you 15rwhp. The small amount of lift a 1.6rr adds will not equate to 15rwhp. Most of the hp gained from a cam is in the duration not the lift. I even spoke to Lloyd Elliot about this in the past.
increasing the rocker ratio always nets you more 'effective duration' even though the cam lobe is the same. The only reason to not over do it is for valve train durability issues.
Think about it this way- lets say a particular valve and port combo only really flows any decent amount of air at .050 lift and above. With the higher 1.6 ratio, the valve gets to the .050 part sooner and hangs open a bit longer on the way closed so the open angle at and over .050" is more degrees of duration that with the 1.5 rocker. So take a tame stock engine like the LT1 that is starving for a bit more flow---easy money.
I understand the idea but I don't think that super tiny amount of increased duration is going to be the part of the 1.6rr formula that nets the biggest gain.
