Difference between LT1 & LT4
Old Jun 29, 2016 | 04:37 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Originally Posted by v8vette84
.....Also I'm pretty sure going from 1.5 to 1.6 roller rockers does not increase duration. How could they? .....
They do change the effective duration. Most cams are rated for duration at 0.050 lift. The cam is a smooth curve from 0 lift to full lift. So the valve lift that is seen at 0.050 with 1.5 rockers is seen earlier (on opening) and later (on closing) when a 1.6 ratio is used.
In practice, the duration does not change that much, but it may be as much as 2 to 4 degrees "effective duration".
Old Jun 29, 2016 | 06:10 PM
ovrebo1's Avatar
ovrebo1
Why would one need to change the spring? Is the LT1 spring closer to binding with the new rocker ratio or is it just a good idea to change out a 20+ year old part?
Old Jun 29, 2016 | 11:16 PM
v8vette84's Avatar
v8vette84
I don't see how this is possible. The lifter "lifts" the 1.6 rocker a certain amount, same amount that it lifts the 1.5 rocker. There is a mechanical connection and the only way to extend the time that the valve is open is to make the cam lobe bigger or the mechanical connection has to be lost. I would really like to know how it's possible.
The valve opens faster so there is a gain in duration BUT the valve also closes faster so there is a loss in duration. Therefore canceling out the effect of the other. (The faster openeing and closing speed is super slight as well)
Am I missing something here?
Old Jun 29, 2016 | 11:17 PM
v8vette84's Avatar
v8vette84
Both.
Old Jun 30, 2016 | 12:01 AM
DrDyno's Avatar
DrDyno
While V8VETTE84's reply of "Both," is correct, the more urgent reason is, as you suggested, to prevent binding. There are cases of the LT1 springs binding with the 1.6 rocker ratio. Changing from the round spring of the LT1 to the oval (flattened) spring of the LT4 is a really, really good idea!
Old Jun 30, 2016 | 12:08 AM
v8vette84's Avatar
v8vette84
Old Jun 30, 2016 | 06:35 AM
kg4fku's Avatar
kg4fku
http://www.superchevy.com/how-to/eng...ker-arm-ratio/
Old Jun 30, 2016 | 08:49 AM
QCVette's Avatar
QCVette
Yes.
kg4fku gave a link that I copied part of below.
"Makes Your Cam Bigger, Too!
An increase in rocker arm ratio nets more than additional lift. It will also change the cam's duration characteristics. Because the increased ratio effectively speeds up valve movement, that means the valve will reach any opening height sooner than it would with a lower-ratio rocker arm. Higher ratios open the valves quicker and close the valves a little later. Since the increase is symmetrical on either side of the cam lobe centerline, a higher ratio will lengthen the overall valve timing, making your cam act bigger. The higher ratio also causes valve timing to increase proportionally as the valve opens farther (see chart above)."
An example might help explain.
If the cam lift is 0.050", the valve lift with 1.5 ratio rockers will be 0.075"
However, with a 1.6 ratio rocker the cam lift only needs to be 0.046875" to get the same valve lift.
So to the duration in degrees from the cam between 0.046875 on the opening side to 0.46875 on the closing side is longer than the duration from 0.050 opening to 0.050 on the closing side.
Old Jun 30, 2016 | 10:13 AM
DrDyno's Avatar
DrDyno
Yup... Magic!
Thanks, QCVette!!
Old Jun 30, 2016 | 05:38 PM
ovrebo1's Avatar
ovrebo1
Crud. Well that dashes my hopes of a quick $150 2 hour 15hp gain LOL
Old Jul 1, 2016 | 08:31 AM
rfn026's Avatar
rfn026
Corvette Rocker Arms 101
Richard Newton
Old Jul 1, 2016 | 04:51 PM
v8vette84's Avatar
v8vette84
So your talking an obscenely small amount of time then?
Ok, so a lifter change increases duration by a nanosecond.
I understand the idea but I don't think it's enough of an increase to really do that much. I feel like 1.6rr's gain is in the reduced friction mostly.
Old Jul 1, 2016 | 06:14 PM
  #33
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by pologreen1
If you are willing to mod, don't let the lt4 be your goal. Good cam, heads, and intake porting will get you 425hp
We're talking a "head and cam" package here.
The LT4 is an LT1 with more aggressive cam, better heads with better porting, more injector, more rocker, and a bunch of "other" stuff. It only got the LT1 to 330-340hp. How can doing the same thing the factory did get an LT1 to 425hp??
Old Jul 1, 2016 | 06:29 PM
  #34
v8vette84's Avatar
v8vette84
He was referring to using a bigger cam and better heads. The LT4 stuff was not insanely better than then LT1 stuff. For the cost of the LT4 stuff you could get more power from aftermarket parts.
Old Jul 1, 2016 | 09:50 PM
  #35
1993C4LT1's Avatar
1993C4LT1
I didn't know they did that much to the LT4. No wonder people say it's underrated.
Old Jul 1, 2016 | 10:11 PM
  #36
pologreen1's Avatar
pologreen1
The heads are barely better. AFR heads will destroy any stock crap head. A real cam even that cam with awesome heads and ported intake with headers will make 400+ Been happening for decades. Not un heard of at all for a 350 with heads, cam, ported short runner intake, exhaust, 1.6rr's making 425 chp. Look up 350ci builds tons of them this range or higher. Street manners? maybe , maybe not
Exactly
They did help, but you are far better off buying aftermarket parts doing a combo than following the gm recipe.
Old Jul 1, 2016 | 11:04 PM
  #37
ColaBear's Avatar
ColaBear
2018 C1 of Year Finalis4
I never understood why GM invested that much in the LT4 for a 1 year run and it only netted them 30 hp more. They would have been better off to introduce the LS1 as the motor for the Grand Sport and 6 speed cars. At least that was a bump to 350 hp.
To Difference between LT1 & LT4
Old Jul 2, 2016 | 10:41 AM
  #38
rocco16's Avatar
rocco16
It was a bump to 345hp, and many LT4's produce power within a few hp of that. The decrease in weight would have been nice, though.
BTW, a little research will reveal that the LT4 heads are a BIG improvement over LT1 heads. GM went milder on the LT4 cam than I would have, but GM had to meet gov't regulations and I don't.
Old Jul 3, 2016 | 07:04 AM
  #39
bac22's Avatar
bac22
And thankfully glad they didn't...the 97 LS1 was woefully overrated by GM in 97 and most LT4's had more HP then 1997 LS1's. Later years of the C5 the LS1 got better with HP.
Old Jul 3, 2016 | 05:36 PM
  #40
Christi@n's Avatar
Christi@n
Originally Posted by tmirisola
Knowing the LT4 has 30 more HP than the LT1 how was this achieved? I would assume the blocks are the same.
Different intake manifold ports
Bigger valves
Different cam profile
Different lifter
Different roller rocker
Lighter pistons
Crankshaft differen too, as far as i remember
