Exhaust Tip modification problem solved
Old Aug 5, 2016 | 02:31 PM
bsbones's Avatar
bsbones
Default Exhaust Tip modification problem solved
Ok I had the same problem that many of you have had with aftermarket exhaust tips that would not fit without shims etc. I have your answer I went to my local auto parts store and purchased an exhaust pipe adaptor it has a 2 1/2 inch outside diameter which fits snug inside your 2 1/2 inch exhaust tip and the other end is 2 1/4 inch inside diameter. This end fits snug over your 2 1/4 inch exhaust pipe, problem solved I'm going to spot weld them so they do not move or come off. The adaptor is about 4 inches long and you have endless adjustment for your new tips to be located in the position you want.I have a 1986
Old Aug 6, 2016 | 09:31 AM
ColaBear's Avatar
ColaBear
2018 C1 of Year Finalis4
Pictures please.
