Catalytic converter
Old Aug 9, 2016 | 03:30 PM
Oceanbiz's Avatar
Oceanbiz
Default Catalytic converter
Hi all
How many catalytic converters are on a 1994 C4 ? At how many miles do they start to go bad or rattle ?
Dan
Old Aug 9, 2016 | 04:08 PM
Nicksvette's Avatar
Nicksvette
Depends on where it was manufactured for, if it's California then there are 3, other states I believe are 2. It can differ car from car for when they go bad but mine lasted till 128k, now I just run straight pipe out the back
Old Aug 9, 2016 | 04:16 PM
Oceanbiz's Avatar
Oceanbiz
Hi, thanks for the reply.
It was manufactured , of course , in KY and bought there and driven to it's first home in Florida.
I am asking because after I drive it for about 3 miles I start to hear a rattle sound sometimes but not continuously. Sounds like from the right side of the car. So I wondered if this car has 3 converters.
53K miles on it.
Dan
Old Aug 9, 2016 | 04:32 PM
Nicksvette's Avatar
Nicksvette
A rattle could just be a heat shield or a nut or a world of other things, but that's not a sign that your cats are bad, bad cats will make your car sluggish and if it gets bad as my car, it actually wouldn't even start.
Old Aug 9, 2016 | 05:02 PM
John A. Marker's Avatar
John A. Marker
For the 94, I believe there are only two cats the pipes then go into a "resonator" which looks like a extra long muffler in the center of the car. Then is splits into two pipes back to the actual mufflers.
Old Aug 9, 2016 | 05:30 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Old Aug 9, 2016 | 09:15 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Originally Posted by zr1fred
Old Aug 9, 2016 | 09:39 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I have a oem driver side if you need one.
Old Aug 10, 2016 | 01:05 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I wonder; Where did you get that information?
OP, the 92-96 have two cat-converters
To Catalytic converter
