Splash Guards
Old Aug 13, 2016 | 07:18 AM
rat123's Avatar
rat123
Default Splash Guards
Hi
I'm Looking for a set of splash guards for my 1984 corvette. What type are there out there. I only basically seen one type. Is there more out there. The only reason I'm putting guards on is that I live on a gravel road. Also can you guys that have splash guards on could you send me pictures what they look like on
thanks
Old Aug 13, 2016 | 09:09 AM
whitemj1948's Avatar
whitemj1948
I don't remember where I bought these, but they do a good job of keeping the crap off of the car.
Old Aug 13, 2016 | 09:11 AM
whitemj1948
They are kind of hard to see but they are there
Old Aug 13, 2016 | 09:14 AM
rat123's Avatar
rat123
Hi
can you take a closer picture of them for me
thanks
Old Aug 13, 2016 | 09:42 AM
whitemj1948
Sorry about the other picture, but that is part of what I like about them they are hard to see and do a good job of keeping the crap off of the car, I live on a road that is chip and seal and has a lot of loose stone on it all the time. Hope this helps you. Mike
Old Aug 13, 2016 | 11:27 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
http://www.corvettepartscatalog.com
http://www.corvettemods.com
http://www.corvetteamerica.com
http://www.corvettecentral.com
http://www.ecklers.com
http://www.madvet.com
Old Aug 14, 2016 | 02:10 AM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
Got these five years ago and still love them, they made by Altec and got them at Funfest.
Old Aug 14, 2016 | 10:45 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I have these same ones on my 85. I thought I would hate them on the car but I really like them. I used black plastic door edge moulding material around the edges of the splash guards so they don't come in contact with the paint. It looks like it was meant to be there. My car being red with black trim, these black guards look very good.
Old Aug 15, 2016 | 09:13 AM
Paul Workman's Avatar
Paul Workman
If you don't do something to protect the paint, that type of splash guard will get dust between the guard (edges) and the paint, and the dirt will act like sandpaper between the guard and the fender. (I too used to live on a gravel road. Ask me how I know!!)
Someone (Ekler's?) makes a clear film that sticks onto the rocker areas. I found that those guards only work well on the area immediately behind the guards. But, the rocker area just a foot back from the guards are NOT protected by the guards, I found.
To really work well, the guards would have to be more like a "mud flap": flexible and hang down to w/in a couple inches of the ground, methinks. YMMV.
Old Aug 15, 2016 | 01:42 PM
3798j's Avatar
3798j
Veteran: National Guard
Installed these abs plastic flaps years ago (after getting fed up continually cleaning the rockers and quarters.)...they're held in place by the fender liner bolts. They do the trick.
Old Aug 15, 2016 | 05:57 PM
hcbph's Avatar
hcbph
Had these on mine when I bought it but one was damaged so bought another. I went a step further and used 'foam in a can' insulation and filled the are beyond where it contacted the body. They seemed a little flimsy to me originally but definitely solid once done.
Old Aug 15, 2016 | 07:14 PM
rat123's Avatar
rat123
Hi
Where did you buy these
thanks
Old Aug 15, 2016 | 10:25 PM
CRUZNC4's Avatar
CRUZNC4
Never had any reliability issues with mine.
Old Aug 18, 2016 | 05:40 PM
corvette Stu's Avatar
corvette Stu
I use them for drag racing to help with burnout rubber getting all over the place
To Splash Guards
