Hood Support
Old Aug 15, 2016 | 10:34 PM
BigRed85's Avatar
BigRed85
Default Hood Support
This is probably a dumb question, but what holds the hood up on a 1985? I just recently got it and saw nothing to hold up the hood when it's open like the prop I've seen on some other Corvettes. While searching for a replacement I saw two small struts. Are the struts the only thing that should hold it up? Thanks!
Old Aug 15, 2016 | 10:46 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
on passenger side
http://www.ebay.com/itm/84-86-CORVET...RV1Nhn&vxp=mtr
Old Aug 15, 2016 | 11:08 PM
BigRed85's Avatar
BigRed85
Yea I've seen those and while I was searching I found the small struts. So if you have to have the prop anyway what do the struts do?
Old Aug 15, 2016 | 11:11 PM
Cruisinfanatic
they help lift the heavy hood. Not meant to keep it up though
Old Aug 15, 2016 | 11:28 PM
BigRed85's Avatar
BigRed85
Gotcha. Thanks!
Old Aug 16, 2016 | 02:36 AM
Cliff Harris's Avatar
Cliff Harris
I suggest using the later model hood support/lock strut. Like this (you also need the top and bottom mounting brackets -- which are included in this listing):
http://www.ebay.com/itm/1986-1987-Co...1XO2WU&vxp=mtr
Old Aug 16, 2016 | 10:58 AM
BrandensBeast's Avatar
BrandensBeast
The previous one probably broke or had to much strain put on it, mine was taken off by one of the previous owners and never seen again, got one from a junked 84 at a junkyard (it was bent where the little tooth on the support clicks into the slot) Bent the metal back and it works just fine.
Old Aug 17, 2016 | 07:30 PM
peyc2's Avatar
peyc2
Cliff that's what I did on my 85, also switched it to driver side, on the passenger side made no sense to me. Easy install, hood already has mounting bolts, just have to make sure the lines in that area on the frame rail are clear of bracket
Old Aug 17, 2016 | 08:26 PM
hcbph's Avatar
hcbph
Here's what mine looks like and I think it's original. Simple scissors mechanism.
Old Aug 18, 2016 | 07:59 PM
CREWZIN's Avatar
CREWZIN
If you get the 88 hood strut (still need brackets), it's a gas strut and it makes lifting the hood soooo easy.
To Hood Support
