Looks like I need a radiator it just started leaking from one of the seams on the side looks like a pita the remove.
Not that hard at all except for the 6 7mm screws in the nose. Get a flat ratchet wrench with some electric tape to help hold some of them. Just pull the top shroud off and the hoses. Good time to pull your knocks and flush it right.
From what I have read they didn't go to dexcool till 96 mine has dexcool in it would it be safe to go back to green after I replace the radiator. ?
If you don't get every last drop out of the old and clean it out very well your wish you never have. Green and dex does not mix at all and will cause a big headache if your not carefull. I would keep what you have
