Heater switch replacement
Old Sep 4, 2016 | 10:53 AM
Woodwright's Avatar
Woodwright
Default Heater switch replacement
The mechanical rotary heater switch in my 86 coupe needs to be replaced as it only works on high speed, sometimes not at all. I have the replacement, but don't know how to access the switch. There are two screws in the dash panel, but they do not allow removal. How do I get to the switch?
Jack
Old Sep 4, 2016 | 06:45 PM
DUB's Avatar
DUB
You thread/post is confusing....'high speed ' deals with the fan....and not the heater.
DUB
Old Sep 5, 2016 | 08:32 AM
Woodwright's Avatar
Woodwright
DUB
Heater = A/C and heater fan switch.
Old Sep 5, 2016 | 09:10 AM
WVZR-1's Avatar
WVZR-1
You remove the trim to get at the control and then replace the switch. You don't need to remove it just be able to handle and manipulate to get to I believe two fasteners. Be care full with temp cable and vacuum lines. With this image of the control and your new part I believe that you can sort it easily.
Name:  C60 AC Contro.png
Old Sep 5, 2016 | 09:29 AM
Woodwright's Avatar
Woodwright
Originally Posted by WVZR-1
You remove the trim to get at the control and then replace the switch. You don't need to remove it just be able to handle and panipulaye to get to I believe two fasteners. Be care full with temp cable and vacuum lines. With this image of the control and your new part I believe that you can sort it easily.
Attachment 48015924
Thanks much. Very useful.
Jack
To Heater switch replacement
