Backup/Reverse light LEDs
Old Oct 5, 2016 | 08:51 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Backup/Reverse light LEDs
I have been slowly replacing the exterior bulbs with LEDs. I have the 4 side cornering light replaced and happy with the lighting. I have a set of Reverse LEDs in the main locations, but they are not very good. I want a set that actually will project light.. not just turn on 'for show'
Has anyone for a good set of LEDs for this location? if not LED, then what did you use
Old Oct 5, 2016 | 09:46 AM
1993C4LT1's Avatar
1993C4LT1
I'm just curious. Where did you buy the reverse LED's from? Retrofitsource has the best of the best
Old Oct 5, 2016 | 09:49 AM
-=Jeff=-'s Avatar
-=Jeff=-
A friend got them for me at a show somewhere a couple years ago.. so I don't know where they came from I just know the output from them sucks
Old Oct 5, 2016 | 06:55 PM
1993C4LT1's Avatar
1993C4LT1
Haven't tried any of their LED stuff. But I did buy HID bulbs off them and they are true 5k(pure white). I'll be doing more LED stuff shortlyhttps://www.theretrofitsource.com/le...to-xb-led.html
Old Oct 5, 2016 | 07:09 PM
-=Jeff=-'s Avatar
-=Jeff=-
Those look good. Might have to try them
Old Oct 5, 2016 | 07:26 PM
1993C4LT1's Avatar
1993C4LT1
I forget if we use 1156 or 1157 reverse lights? But I know it is one of the two
Old Oct 5, 2016 | 07:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
Old Oct 6, 2016 | 11:00 AM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Have you checked onhttps://www.superbrightleds.com/ ?
They have an index for replacement of common auto bulbs and a good description of performance of each LED, color, power, luminance, etc.
Can be a little pricey on some model numbers *cough*amazon.
Old Oct 6, 2016 | 12:03 PM
Goldcylon's Avatar
Goldcylon
Did you have to modify the corner light LEDs to get them to fit correctly ? Where did you get them from
Old Oct 7, 2016 | 02:48 AM
Cliff Harris's Avatar
Cliff Harris
LEDs are like a flashlight. They have a very sharp beam with no light emitted to the side. The way to get around this is to put in multiple LEDs pointed in all directions.
I suggest something like this:
https://www.superbrightleds.com/more...rofit-car/526/
Old Oct 7, 2016 | 07:26 AM
-=Jeff=-'s Avatar
-=Jeff=-
Found some on eBay, I forget if you have to modify them, I am thinking yes.. when I have time I will look at them
I have something like that.. they don't work so well
Old Oct 7, 2016 | 07:42 AM
1993C4LT1's Avatar
1993C4LT1
The ones I linked have 500lm, the superbright leds have 250lm.
Old Oct 7, 2016 | 07:44 AM
-=Jeff=-'s Avatar
-=Jeff=-
I guess worth a try
Old Oct 7, 2016 | 07:50 AM
WVZR-1's Avatar
WVZR-1
I believe the issue with reverse lamps is how the socket is located in the lamp. I don't believe that all C4's are the same, I think likely 3 different sets. If the socket is "side entry" you can't use a projection bulb and the link Cliff provided would be the usual approach. If the socket were a "rear entry" you could use a "projection bulb" that WORKS. Are there bulbs similar to what Cliff linked that have greater/more intense lighting? Maybe. Do you modify the housing and the reflector/reflecting surface of the housing? Likely the only way to create a "functional beam" for actually using them as you hint you'd like.
Old Oct 7, 2016 | 07:54 AM
WVZR-1's Avatar
WVZR-1
Your link also appears to go to an 1157 replacement and that ain't right!
That's a projection bulb (I believe) and would work well like I mentioned with a "rear entry" - with "side entry" I don't think so.
Old Oct 7, 2016 | 09:57 AM
1993C4LT1's Avatar
1993C4LT1
If you look on their site, they also have 1156. I linked the 1157 because I wasn't sure if it was 1156 or 1157.
Old Oct 7, 2016 | 11:20 AM
Raidmagic's Avatar
Raidmagic
What about separating the housing and placing a board of LEDs in the housing and gluing it back together.
To Backup/Reverse light LEDs
Old Oct 7, 2016 | 04:30 PM
-=Jeff=-'s Avatar
-=Jeff=-
if the light is projected they will work, I have LEDs I believe they seem bright, but don't project.. I might try the Morimotos, that might be just what I need
Old Oct 7, 2016 | 11:19 PM
Goldcylon's Avatar
Goldcylon
Lmk bro I'm going there next. I just ordered them
Old Oct 8, 2016 | 10:04 PM
-=Jeff=-'s Avatar
-=Jeff=-
might give these try
https://www.amazon.com/gp/product/B0...YANTKPD4R54B56
