This was a little troubling to say the least - I took advantage of an opening in my schedule and a dry 45 degree day - to take the car ('85 standard 4+3) for a drive. I had not tested the heater and defrost out really until today either - while on the freeway with the heat on - I noticed the windows were fogging up - so I cracked them open to clear them and turned the heat off
- I did not think too much about it until I got home and noticed smoke coming in the back around the hatch and the car was filling up as well I shut everything off, opened everything up to air it out - but- I have no idea why it started to do that - I had not noticed it before and it seemed to be running fine - last time I checked smoke in the car is bad
I am supposed to be driving it again this week to show some friends the car - but this concerns me a lot
any thoughts or suggestions on what this might be ?
I am not - but there was a lot of smoke - The problem was when I got out in the garage - the car had been running a little while in the garage so I may had been smelling that
steam from the heater core - does that mean a leak?
Sean
Very well could be I can not see it from here. But good chance I will hear a few new words.
If its the heater core and you can't have it repaired quickly, pull off the in and out heater rubber tubing at the firewall and install a "U" tube bypassing the core. You can find the tubing at a good auto store or make it yourself from copper tubing if you know how to bend it.
If it's the heater core, your windows will be covered with a film of antifreeze. If it was actual smoke......no film. but sounds like mist from the heater core.
