88 vette
Old Dec 16, 2016 | 05:57 AM
tazwayneiac's Avatar
tazwayneiac
Default 88 vette
i just picked up a abandoned 88 vet
the dash/windshield vin num is so rusted it can't be read
where else can I look to find a vin number?
any help will be appreciated!
Old Dec 16, 2016 | 10:08 AM
BrandensBeast's Avatar
BrandensBeast
Pretty sure the Vin is on the side of the engine block aswell, mine was rusted horribly but could still read the vin after closely looking at it under the windshield.
Old Dec 16, 2016 | 10:13 AM
HAD2HAV2's Avatar
HAD2HAV2
Pitiful, an abandoned Vette.
Old Dec 16, 2016 | 08:35 PM
JungleCat's Avatar
JungleCat
St. Jude Donor '05 thru '26
Did you check the sticker on the inside of the driver's side door?
Old Dec 17, 2016 | 07:43 PM
hcbph's Avatar
hcbph
Assuming you got a title and it goes with the car, should be on the title.
Old Jan 12, 2017 | 01:07 PM
tazwayneiac
actually I picked up 2 abandonded vets...88 and ..84...yes very pitiful
Old Jan 12, 2017 | 01:08 PM
tazwayneiac
no title...have to get it jacked up to check where they say might b vin numbers on tranny
Old Jan 12, 2017 | 01:09 PM
tazwayneiac
I did ...its painted over
Old Jan 14, 2017 | 11:47 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
I think the SPID label has the vin on it as well.
I don't remember on the '88, but it is usually located under the rear compartment storage lids or under the console lid. It should have the vin and also what options were on the car when new.
Sad that it was abandoned, but good luck bringing it back.
Old Jan 14, 2017 | 01:54 PM
c4cruiser's Avatar
c4cruiser
Remove the driver's side lower wheelwell panel and the last 8 (maybe 10) digits of the VIN are stamped on the vertical portion of the frame rail just below the battery.
The first eleven digits of the VIN will be common to Corvettes:
1G1YY2 (or 3)18*J5******
1 Country of origin (USA)
G General Motors
1 Chevrolet
YY Corvette
* Body Style- 2 for a Coupe or 3 for a Convertible
1 Manual seat belts
8 Engine Type (L98)
* Check digit and will vary)
J Model year (1988)
5 Bowling Green Assembly Plant
****** sequential build number
I had also heard that the entire VIN is stamped on the top of the frame rail in the passenger side wheel well just forward of the "dog bones" but it would take some disassembly to get to it.
If the car has the original auto trans, the VIN will be stamped on the passenger side of the case just above the fluid pan.
To 88 vette
